Camber Shims #629748 07/24/05 11:40 PM
FrankR Offline OP
Anybody have any spare camber shims they want to sell? Or better yet, anybody want to volunteer to make some for sale? Last time I checked, they are no longer available from MMC.
Frank
Re: Camber Shims [Re: FrankR] #629749 07/25/05 02:53 AM
DougH Offline
Mitsubishi Forum Moderator
Would genII ones have the spacing for the bolts? Those are still in production.
DougH
1995 SR - RIP
1993 RS - RIP
Re: Camber Shims [Re: FrankR] #629750 07/25/05 05:55 AM
52degrees Offline
I'd call Napa. I think they are pretty generic. Pretty much a shim's a shim.
I looked at mine and they looked a lot like Chevy shims.
Clay
KG6VNX
Re: Camber Shims [Re: DougH] #629751 07/25/05 11:20 AM
FrankR Offline OP
Dunno about the GenII - I'd think if they were the same, the Gen1 part number would be the same or superceded by the GenII number and still available.
I can cut them from stainless flat stock, but someone with milling equipment could run most any custom thickness.
Frank
Re: Camber Shims [Re: FrankR] #629752 07/25/05 02:17 PM
W
wyleone Offline
I just used the run of the mill fractional shims that Carquest sells. I also cut one of the OEM camber shims when I had to correct for Caster.
Re: Camber Shims [Re: FrankR] #629753 07/25/05 02:21 PM
DaphneD Offline
Frank, I don't know what your dealer smokes, but they are still available and for relatively cheap too.
Heh, that's not necessarily true. GenIs (not 2.6L) and GenIIs share the same center link and a few other things that go by different part numbers. When I used to work in the engineering dept of a company that made printing equipment, I came across quite a few parts that were essentially the same part, but had a different P/N because the engineers never bothered to check drawing references. Consequently, there were like 10 different drawings for the same bracket. <img src="/forums/images/graemlins/drunk.gif" alt="" /> Engineers. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: Camber Shims [Re: DaphneD] #629754 07/25/05 02:23 PM
FrankR Offline OP
Thanks, Doug -
I'll try them again.
Frank
Re: Camber Shims [Re: FrankR] #629755 07/25/05 02:30 PM
Houston Offline
WOW, super timely subject matter. I justed called my local NAPA this morning on the very thing. They list and stock a box of 3mm thick shims for the Montero, comes in a box of 25, for $7.10. Sounds ok for me. I'll list a part number once I pick them up if you're interested in them. <img src="/forums/images/graemlins/cheers.gif" alt="" />
'92 SR Montero, Green, with 31" Yokohama Geolandar A/T Plus Tires, Mitsu factory fog light kit, on-board air compressor,Sony Radio and 10 disc changer. 213K and counting.....
Stock & Happy otherwise
Re: Camber Shims [Re: Houston] #629756 07/25/05 02:37 PM
FrankR Offline OP
Absolutely - thanks a bunch! MMC FSM indicates the OE shims are available in 1mm and 2mm. 1mm = ~ 13 minutes of adjustment.
Frank
Re: Camber Shims [Re: FrankR] #629757 07/25/05 03:16 PM
Houston Offline
OK, part number is 264-1003, and they are 3mm in thickness. Which means you only get a "crude" adjustment out of them when compared to the thinner shims offered by Mitsu. So, I can hope that one of these babies will take the place of several shims I already have installed on my upper arm pivot, and use the remaining thinner shims to get my smaller adjustments. Either that, or take the 3mm NAPA shims to a grinder and thin them out myself <img src="/forums/images/graemlins/wink.gif" alt="" />
Hope this helps you out. PS, they're straight bodied, no offset lip to them, and appear to be galvanized too.
PHP: 7.4.33 Page Time: 0.016s Queries: 16 (0.012s) Memory: 0.6363 MB (Peak: 0.7604 MB) Data Comp: Off Server Time: 2026-11-18 22:05:28 UTC
