Re: attention those who have aftermarket wheels (rockcrawler wheels)
[Re: off-roader]
#630627
07/28/05 06:03 AM
the wheels that i am getting are 16" wheels, so just to clarify any confusion with those who run 15"s
[Re: grifter679]
#630628
07/28/05 06:11 AM
Well I checked American Eagle tires website & it looks like Alex is running 4.5" of backspacing on his 16x8 rim. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: off-roader]
#630629
07/28/05 01:37 PM
My wheels have +2mm offset. I would stay in that range for 285s. Ray you should check tirerack.com, they have them in stock, there are plenty (almost all) of manufacturers present with tire of this size.
92 SR, 285/75R16 Yoko MT ARB locker GAST compressor AirLift 1000 MM10500 Snorkel custom rear bumper 02 Montero LS died protecting the master 08 PowerWagon (stock!)
[Re: Alex Kogan]
#630630
07/28/05 01:47 PM
Also. Neverminde special deal I got on wheels and tires I specifically wanted 285s over regular 33x12.50/R15.
[Re: Alex Kogan]
#630631
07/28/05 03:20 PM
The original post asked what backspacing and or offset should i look for to make sure that my tires do not rub, and that the spacing is correct? . It does not matter if they are 15 or 16 inch rims.
[Re: Alex Kogan]
#630632
07/28/05 05:11 PM
My wheels have +2mm offset Grifter679, In case you're wondering... here's a link to the full spec's on Alex's wheels, per the manufacturer's website... http://www.eaglewheels.com/149.htmHis rim p/n is 1499-7865 & 1499-7866 (different for left & right rims). Just make sure the rims you buy rims have a similar spec and you should be okay. <img src="/forums/images/graemlins/kewl.gif" alt="" />
