Re: Radiator Question [Re: wyleone] #630822 07/28/05 04:26 PM
grass13 Offline
didnt we have this discussion a while back <img src="/forums/images/graemlins/confused.gif" alt="" />. btw, its just bad idea waiting to happen to use the tranny cooler for the oil. besides, you should leave it as is for when you get around to upgrading to a autotranny. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Radiator Question [Re: grass13] #630823 07/28/05 11:14 PM
Roll_me_over Offline OP
hey it was just a thought and I didn't really think about it just the idea came to me so I posted it... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Now that I do think about it, I agree with you Johnny...
02 Ford F-250 4X4 PSD...zero body damage
67 Weimann 18' Jet boat...zero body damage except for the trailer drags on the ground from time to time
Re: Radiator Question [Re: Roll_me_over] #630824 07/28/05 11:56 PM
The shower idea rocks, though. I'd think that with a low flow rate/pressure, the water would heat up pretty good in one pass with the truck running. Or you could make a hot fudge dispenser, I suppose.
Re: Radiator Question [Re: JohnnyBfromPeoria] #630825 07/29/05 12:05 AM
DanWheeler Offline
if not i think it would be easy enough to setup a pump and a valve to either send the heated water through a shower head or recirculate it into a bucket... and then of course you'd want to setup a mixing valve from your cold water source to get just the right temperature since your hot water source will be 180 degrees or so after circulating through a few times <img src="/forums/images/graemlins/wink.gif" alt="" />
1986 Montero 2.6l
31X10.5 BFG MT - Weber carb with custom intake
Rear LSD - RCI seats - Oil cooler - Manual hubs
Custom bumpers front and rear + rock sliders
Re: Radiator Question [Re: DanWheeler] #630826 07/29/05 12:26 AM
FrankR Offline
One thing you wouldn't want to do is to subject any part of your hot radiator to a repeated shock of cold water input.
Frank
Re: Radiator Question [Re: Roll_me_over] #630827 07/29/05 12:50 AM
Monty Offline
I just bought a Radiator from Radiator Barn, and I must say its a nice pice. every thing lined up fine, but the only problem was it had the smaller fill neck, so I had to get a cap for the v6.
1989 Raider V6/MT
2005 Jeep Liberty CRD Turbo Diesel
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6173 MB (Peak: 0.6874 MB) Data Comp: Off Server Time: 2026-06-09 23:39:52 UTC
