1990 2.8LV6 A/C idle control?
#631312
07/29/05 03:41 PM
What controls the A/C idle control speed? Isnt there a switch that increases the idle when the A/C is on? If so, where is it? I dont think my truck is ideling fast enough when stopped and in "Drive" such as at stop lights. My A/C compressor kicks off, but if i give it some gas and increase the RPM's it will kick back on.
Also, where do i ramp up the "global" idle speed? Where is the idle air control valve?
1990 Isuzu Trooper 2.8L V6
Re: 1990 2.8LV6 A/C idle control?
[Re: greauxpete]
#631313
07/29/05 11:21 PM
IAC valve is the valve that sticks out at 3:00 looking down at the engine. It is a pintle with a rotating stepper motor that retracts allowing air to go around the throttle blades. The Idle air control is set through a procedure you can find here: POST.........
CHRIS 98 Amigo, 92 Pup
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5871 MB (Peak: 0.6352 MB) Data Comp: Off Server Time: 2026-06-19 20:48:11 UTCValid HTML 5 and Valid CSS
