Re: yota shackles
[Re: allsierra123]
#633889
08/18/05 04:03 PM
my shackles are bigger than the ones you have in the pic. Could be a mod the previous own did.he did do a lot of stuff to this truck before I got it. Could be, You can use Toyota OEM shackles too but I don't know what the specs or the ## are and I don't know of anyone that has used them. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: yota shackles
[Re: wyleone]
#633890
08/18/05 05:14 PM
Im gonna get some measurements for you guys.But I have no way of knowing what they came off of.
91 Mitsu Montero RS LWB PENDING 88 Cherokee Lifted and modded heavily. FOR SALE 91 vanagon syncro 1.9 TD SOLD 04 Suzuki Aerio Commuter SOLD 90 mits mighty max,v6 SOLD 94 Mits Diamante LS. Stock. TOTALED 71 VW Baja Bug SOLD
Re: yota shackles
[Re: wyleone]
#633891
08/18/05 06:27 PM
Dear Customer: Thank you for doing business with Summit Racing! We thought you would like to know that the following items have been shipped.
WOOHOO
2001 Jeep Wrangler Sahara/4" Rough Country Lift/BFG 32x11.5x15 I caught this "JEEP thing" of your and now it hurts when I pee.
Re: yota shackles
#633893
08/20/05 04:47 AM
Yeah, I have seen that page
Keep in mind...
...you are now 2 inches hihacklesgher in the rear. Your shocks are extended 2 inches at park. Now is a good time to add longer shocks, and extended brake lines, in order to use that new found height and flex.
So, what size shocks do I need.
BTW, shackles arrived today.
Re: yota shackles
[Re: juggernaut]
#633894
08/20/05 04:39 PM
Make sure you replace the brake line first so the drop of the new shocks do not pull it apart. I have not replaced my shocks because I found with the OEM shocks at full extend, the driveshaft starts to bind, Unless I drop the xfercase to suit. I am not gong to install longer shocks. If I break one, oh well.
Re: yota shackles
[Re: allsierra123]
#633896
09/18/05 02:44 PM
I recommend taking the big thick spring off the bottom and replacing it with an add-a-leaf kit for beter articulation. I do not have a stiffer front with cranked Tbars. I do have the larger diameter bars though. I also use softer shocks and no sway bar. Rides great but don't try to make a quick turn. <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> Bob Shaw
