shimless Free wheeling hub? #634337 08/08/05 04:59 AM
V
v6lsmonty Offline OP
Was wondering if the lack of shims in my hubs is normal??? According to the factory manual there should be shims between the c-ring and locknut. Is this a problem?
I looked up the factory part # MB290675 and its $7 oem. Is there an alternative if I should need to replace them?
My hubs seem to work fine.
1989 Montero LS (sold)
1994 Cherokee Country bone stock
Re: shimless Free wheeling hub? [Re: v6lsmonty] #634338 08/08/05 05:07 AM
W
wyleone Offline
I have one behind each c-clip. They are very thin, I doubt you will find a washer that thin that you could use. I wonder if that price is for a multi pack?
Re: shimless Free wheeling hub? [Re: v6lsmonty] #634339 08/08/05 08:18 AM
FrankR Offline
MB241229 is the shim set (for 1 hub) with several assorted washer shims.
To determine what (if anything) you need:
Make sure the t-case is not in 4WD and the hubs are not locked. With the clip installed on the axle, reach behind the hub and grab the axle joint - rotate it forward and back until you can judge the limits of free play and set it at the mid-point between forward and back resistance. The mid-point is where you have maximum axial end play. From this position, push/pull the axle in and out. Standard spec range is 0.008 - 0.020". Use the shim from the assortment that puts end play in spec.
Good luck,
Frank
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5925 MB (Peak: 0.6461 MB) Data Comp: Off Server Time: 2026-06-24 00:33:33 UTC
