Brake Pad Sensors on '02 Trooper??
#634523
08/08/05 08:21 PM
Hi, Does anybody know if there are front brake bad sensors that will squeal on an '02 Trooper when the brake pads are worn out? Thanks in advance ... Fred.
Re: Brake Pad Sensors on '02 Trooper??
[Re: parkstribe]
#634524
08/08/05 11:52 PM
THEY ARE NOT REALLY SENSORS IN THE TRUE TERM AS IN ELECTRICAL SENSOR , BUT THEY ARE SQUEELERS ON EACH INSIDE BRAKE PAD THAT RUBS AGAINST THE ROTOR WHEN THE PADS WEAR OUT, THEY ARE PART OF THE METAL SHIM THAT GOES IN BEFORE THE PADS GO ON ,USUALLY WHICH ARE LEFT OUT ON AFTERMARKET PADS , SAME DESIGN AS ON THE REAR JERRY
[Re: JLEMOND]
#634525
08/09/05 08:48 PM
Thanks Jerry. You are THE MAN as usual!! I wanted to know that I'll hear the squeel if/when the pads get thinned to that point. Thanks again ... Fred.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5923 MB (Peak: 0.6452 MB) Data Comp: Off Server Time: 2026-06-07 06:20:31 UTCValid HTML 5 and Valid CSS
