Snow plow for a Sportage??? #635148 08/10/05 07:16 PM
Has any one seen or used a Sportage to plow snow? If so with kind of plow was used? <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Snow plow for a Sportage??? #635149 08/11/05 11:14 AM
Axe Man Offline
Kia Moderator Emeritus
I've never seen a Sportage with a snowplow. And I live in snow country. I'm not sure if there's any brand of plow that will fit unless you make major mods to the front.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: Snow plow for a Sportage??? #635150 08/11/05 03:01 PM
a good plow installer should be able to fit one up I would think. A buddy of mine's brother worked at a place and he used to tell me all sorts of different custom plow applications.
Re: Snow plow for a Sportage??? #635151 08/11/05 04:36 PM
I dont think a sportage is built for plowing snow. you'll probably screw up the front end on it. for plowing, you need something like a 3/4 ton truck, mainly because those have the chassis built for this kind of application, and the engine to push that snow around too.
Re: Snow plow for a Sportage??? #635152 08/11/05 06:13 PM
A
Airdale73013 Offline
I suspect the Sportage is up to the task of plowing. I assume you are not going to install a 15' blade and use it comercially. The Sportage is not just little and cute, it is at its' core a truck. <img src="/forums/images/graemlins/angry.gif" alt="" />
Re: Snow plow for a Sportage??? #635153 08/11/05 06:20 PM
Out of curiosity, what do you drive?
Nevemind.... I just looked up your previous posts and found out that you drive a 2wd ranger that you're trying to convert into a 4x4 right?
You'd be surprised at what a 1st gen sportage can handle. Looks innocent enough but the frame underneath and the way it's built speak for itself.
Now the 2nd Gens... They're unibody.
Re: Snow plow for a Sportage??? #635154 08/12/05 01:18 AM
I have seen snow plows at Walmart that are universal(never looked to close to see how much modification needed) they use a winch to raise and the angle is manual. I have seen these installed on a Sidekick, Cherokee and a F150. They say on them that they are not meant to travel on roads so are equiped with quick release. Snowbear is the brand and they have no listing for Kia, but you could check out thier website they may have something that will fit with mods.
Re: Snow plow for a Sportage??? #635155 08/12/05 01:31 AM
Nukeiridium Offline
Does someone actually WANT to plow snow with their Sportage or is this more of a rhetorical question? <img src="/forums/images/graemlins/confused.gif" alt="" />
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: Snow plow for a Sportage??? [Re: Nukeiridium] #635156 08/12/05 10:55 AM
Calappoyas Offline
Sure, why not? My father lives deep in the high desert and snow plows using his 2dr 1st gen Montero (with tire chains) when ever it snows enough. keeps the snow level from getting too high, and causing a real problem.
02 [color:"red"] Sportie [/color] 5sp 4x4 2dr. 1?" Body + 4" Rocksportgear lifts, 31x10.50 Wildcats M/Ts, Manual Hubs, Yakima rack, basket. Redline gear oils
http://www.cardomain.com/id/calapooyas
My beater, 03 Land Rover Freelander SE3
Re: Snow plow for a Sportage??? [Re: Calappoyas] #635157 08/12/05 01:25 PM
Dave Scott Offline
so we're talking for SMALL jobs, not plowing city streets, right? good, cuz i don't think the Sportage will be well equipped enough, nor really have a desirable amount of power to do much of this so-called "snow-plowing," you speak of.........
my location: south texas- i.e.- me no understand, what is "snow?"
<img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/shiner.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.011s) Memory: 0.6277 MB (Peak: 0.7489 MB) Data Comp: Off Server Time: 2026-11-18 03:34:52 UTC
