Re: Smokeless Oil ??? [Re: bearcatfans] #635824 08/12/05 10:35 PM
BobShaw Offline
Switch motor oil to Castrol GTX 10w40. Castrol has a very higher burning (flash) temperature and will not burn away as fast. It has worked for me for 40 years.
My engines with 125K, 192K and 235K miles used no oil. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Bob Shaw.
Re: Smokeless Oil ??? [Re: BobShaw] #635825 08/12/05 11:06 PM
bearcatfans Offline OP
currently using castrol gtx 20w-50 for my worn engine.
-aaron
Re: Smokeless Oil ??? [Re: bearcatfans] #635826 08/12/05 11:11 PM
LRJ4x4 Offline
So the oil does not smoke when burned, it still burning and clogging your O2 sensors and catalytic converter. This stuff may work but it's the stuff used car dealers buy to sell you a POS smoking car. It's evil and nothing good will come of it. <img src="/forums/images/graemlins/evil.gif" alt="" />
Find a shop that will do your seals, if not in your area then drive to somewhere they will <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Smokeless Oil ??? [Re: bearcatfans] #635827 08/12/05 11:41 PM
W
Winston Offline
OOPS. I forgot you were the one who tried Auto-Rx before. Have you tried using a good "high Mileage" oil like Valvoline Max Life in a nice thick 20W50 weight? It might help a bit with the seals and since it is nice and thick, that should help too.
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
Re: Smokeless Oil ??? [Re: bearcatfans] #635828 08/13/05 02:11 AM
Alex Kogan Offline
ALL the shops I talked to here (Dayton, Ohio) said they would have to send out the heads to be machined and all kinds of other work would need to be done. NONE would just do the seals and reassemble the engine. (The Mitsu. factory shop manual shows 16.5 hrs. per side of the engine to do the seals on the DOHC V6 3.5. That's 30 hrs. of labor at $70+/Hr. + Machining & parts <img src="/forums/images/graemlins/barf.gif" alt="" />
-aaron
You are talking about head rebuilt here not just seal replacement. It's not necessary to remove heads to replace the seals. Can be done on the car itself. Still those prices are outrageous. You can get brand new head for $600-700
08 PowerWagon (stock!)
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6117 MB (Peak: 0.6758 MB) Data Comp: Off Server Time: 2026-06-23 04:50:25 UTC
