glowplug controller and fuel filter assembily on the c223
#636095
08/13/05 09:09 PM
Allrighty!, where to start.... im doing a c223 conversion into a s10.... i have most the harness and controller fuel filter etc from the c223. ive completely eliminated everything engine related from the s10 no computer no insterment cluster, i'll be using all aftermarket gauages... but can i get a detailed explination of how the glow plug controler works? inputs and outputs, and how the fuel filter/water seperator works.... so i can wire in indicator lights that would have come from these units.... currently im started body work and i have the engine on the chassis.... but im not far off from diving into electrical work! any halps appreciated!!!
2002 3.9L dodge dokota 2x4 <img src="/forums/images/graemlins/frown.gif" alt="" /> and one C223... so far <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: glowplug controller and fuel filter assembily on the c223
[Re: modern_cowboy]
#636096
08/23/05 10:11 PM
If you PM me your address (or fax number) I can send you the wiring diagram for the 223. In regards to the water fuel seperator - trash it and just convert to a standard fuel filter.
86 Isuzu Trooper TD 5 speed 82 Isuzu Diesel I-Mark 86 300 SDL MB 126 85 300SD MB 126 82 300 D MB 123
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5873 MB (Peak: 0.6355 MB) Data Comp: Off Server Time: 2026-07-17 07:40:06 UTCValid HTML 5 and Valid CSS
