So I go to Harbor Freight and spend 119 .......
#637291
08/16/05 05:29 PM
Re: So I go to Harbor Freight and spend 119 .......
[Re: ZUK]
#637292
08/16/05 05:51 PM
ahhh, porta-mig. pretty cool!
i've got that same one(bought it for chuckles) and it's actually treated me pretty well. not very good for welding exhaust(as any flux core isn't) but works great on a little thicker stuff.
'79 sport 4x4 longbed <img src="/forums/images/graemlins/smile.gif" alt="" /> 20/22R hybrid with EB's OS valves, 268c cam, offy intake, weber 32/36, thorley header, 5 speed swap, 34" LTBs, downey 3" springs, marlin hysteer, 4.88s and locked
'91 4x4 shortbed 22R-E, W56, the dd!
[Re: ZUK]
#637293
08/16/05 06:03 PM
I got that exact same welder. If you end up NOT using some of the parts, send them my way, especially the roller/feed assembly.
[Re: Adam F]
#637294
08/17/05 12:18 AM
I got that exact same welder. If you end up NOT using some of the parts, send them my way, especially the roller/feed assembly. sorry...the motor/roller/feed is the core of the set-up....but I am throwing away the wire speed controller board I was hoping this would be snip and clip and ready to use a portable MIG. Hooking up 2 motor-cycle batteries in series to the MIG's hot hire worked excellent....but the thing that was acting up was the wire speed......the controller board did not like pure 24vdc. So I clipped it out and ran my own separate regulated adjustable 12vdc source and it works great as seen in the pics below. Soooo now I have 2 trail MIGs <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> ![[Linked Image]](http://img.photobucket.com/albums/v221/kenfrancisco/8fec1090.jpg) ![[Linked Image]](http://img.photobucket.com/albums/v221/kenfrancisco/8607eccf.jpg)
[Re: ZUK]
#637295
08/17/05 12:40 AM
The regulator circuit is amazingly simple ![[Linked Image]](http://img.photobucket.com/albums/v221/kenfrancisco/21add09b.jpg)
[Re: ZUK]
#637296
08/21/05 03:15 AM
Looks to me like its out on trail with you after some mods is it goin to run off 12 volt.
[Re: ZUK]
#637297
08/21/05 03:19 AM
Hmmm....could you explain the mods in a little more detail for me? Sounds like you just unhooked the 120vac transformer and hooked up 24v to the mig portion and 12v to the roller?
[Re: ZUK]
#637298
08/21/05 04:52 AM
ZUK that is freakin' awesome! I want one!
$120 ya say... hmm... now how to get dual batteries on the 4runner...
[color:"darkgreen"]1986 4Runner - 4" IFS - 63" Chevys - 33" ATs - 5.29s - Rear Detroit Sliders - Kayline - Rebuilt 22RE - On Board Air AND Factory AC www.xtremefabricator.com[/color]
[Re: ZUK]
#637299
08/21/05 04:53 AM
Just noticed you were holding up a 110 cord in the picture... such a clown <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
[Re: TheBandit]
#637300
08/21/05 03:31 PM
A few years ago I picked up an old Hobart wire feeder unit off of eBay. Basically the same thing, just doesn't have any internal power at all. All built to run off the welding feed power. Right now it is set up for flux core only, but I picked up some parts to try and adapt it to run gas if needed.
