Iridium spark Plugs pros/cons
#638771
08/20/05 06:22 AM
Has anyone personally used these things? Denso makes them for like $8? each. I was going to change the plugs on my girlfriend's mom's Lexus RX300 and when I pulled the 1st plug noticed they were Denso Iridiums & looked like new at 75K. I'm currnetly using NGK V grooves for about $2each and change them about every 15K. My brother is thinking about putting a set in his LS1 Trans am. changing plugs in that car SUCKS. So, anyone know anything about them?
94runner: Dana 44 SAS, 35's, Lockers, gears, winch, rock rails, bumpers, 3"BL, drivetrain lift, Budbuilt cross member, centerforce clutch and MORE! ***FOR SALE*** $8,500 -1985 Supra (STOCK!) FOR SALE $4,000 www.celicasupra.com
Re: Iridium spark Plugs pros/cons
[Re: J94_4runner]
#638772
08/20/05 10:14 AM
Ive got them now and theyre not bad at all but theyre more expensive here like 14.00 ea. I say go with them they aint gonna do any harm and they last like 60k.
89 K5 Blazer,TBI 350, 700R4, 6" lift, 40" groundhawgs,3/4 ton 14 bolt rear, 3/4 ton 10 bolt front, 4.88:1 Gears
[Re: 4mudder]
#638773
08/20/05 05:15 PM
Been thinking about going to the Iridium plugs too. My father has them in his jeep and it made no difference. Just recently read a post on Pirate about the Iridium plugs and BlueCoyote3 was talking about using the double electrode plugs used in the 5vzfe (3.4 Taco motor). They fit the 22r/re with no issues. What makes them 'good' is that the spark kernal is out in the open, not hidden behind the electrode and they are only $1.69 at Autozone. Part #'s are: NGK BKR5EKB Denso K16TR11 I may try this and see how well it works.
Adam W. 87 4Runner SR5 - 22RE w RV head & TRD Cam, LCE header, W56B-HD, 4" Stage II, 1.5" BJS, Rancho T-bars, F 5.29, R 5.29 ARB V6 FF w LC disks, 35" MT/R's
85 4Runner frame, 5" Marlin springs, 5:29 ARB HP front. Work in progress - Always!
[Re: D-runner]
#638774
08/20/05 06:28 PM
i've thought of trying those taco plugs as well. i wonder how one gaps them?
'79 sport 4x4 longbed <img src="/forums/images/graemlins/smile.gif" alt="" /> 20/22R hybrid with EB's OS valves, 268c cam, offy intake, weber 32/36, thorley header, 5 speed swap, 34" LTBs, downey 3" springs, marlin hysteer, 4.88s and locked
'91 4x4 shortbed 22R-E, W56, the dd!
[Re: kyle-22r]
#638775
08/20/05 07:13 PM
I replaced the plugs on my girls 3.4. weird looking NGK plug. I think I'm just gonna stick to my NGK Vgroove 1 colder for my 3.0.
[Re: J94_4runner]
#638776
08/20/05 11:50 PM
iriduims are usueally 12 or 13 are you sure there not denso or ngk platinums?
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
[Re: willzrunna96]
#638777
08/21/05 01:12 AM
i thought they were $8each but guess they're more. Screw it, i'm gonna stick to NGK's. I'll tell my brother only pro is longer change interval. for him it makes a difference, for me it doesn't.
[Re: J94_4runner]
#638778
08/21/05 03:46 AM
You can get the NGK Iridiums plugs from Advance for $6.96.
They're part # BPR5EIX for my 85 4runner w/22re, I've been thinking about trying them out.
Weird thing is the iridiums carry a 3 month limited warranty and the standard plug carries a 2 year replacement warranty.
[Re: Runningman]
#638779
08/21/05 04:02 AM
well, for $7each I might throw a set in next time. give'm 60K of use. It's actually cheaper in the long run. But I wonder if they really last 60K. I've tried Bosch platinum plugs before in my Vette & supra and HATED them. my vette had this "mystery starting problem". Very hard starting.. sometimes had to crank it 5 times to get it going. Buddy of mine told me it was the Bosch plugs and to try NGK V grooves or regulars and i did. never had the starting problem again. Only thing that changed was the plugs. So I've already been bitten by expensive plugs before.. that's why i'm weary now about iridiums.
[Re: J94_4runner]
#638780
08/21/05 06:35 AM
I've had the Bosch platinum 4 electrode plugs in my 22RE for 100k miles now and theyre as good as the day I put them in! For all who say Denso and NGK is the only way to go I say not so. If you dont like changing plugs, go with Bosch. They work as well if not better than Denso.
'04 Taco x-cab 3RZ FE stock (daily driver) '90 x-cab 22RE stock '82 Hilux 6" lift (ACES HI) '82 2-Hiluxs' Rally Edition (parts) '81 Hilux 3" lift (parts/restore)
