Solid front axle #638891 08/20/05 06:34 PM
Scorpion1971 Offline OP
Been looking to get a 4 runner and was wondering what was the last year they came with the solid front axle, and also have a V6. Also are some years better than others.
1988 4 Runner
Re: Solid front axle [Re: Scorpion1971] #638892 08/20/05 06:39 PM
Adam F Offline
4Runners had solid axles in 1984 and 1985. 84 had a carb and 85 had EFI, both 4cy, v6 wasn't available until 1988.
Read up on the history of 4Runners here
http://www.top4runners.com/ja/runhist.html
If you want a V6, you can do like I did and buy a 88 4Runner with a V6 and convert to a solid axle
www.toyotaoffroad.net/afertig/88/sas
Not a whole lot of differences over the years besides the obvious front suspension changes. 86 and up got a 3" wider rear axle, V6 trucks got bigger brake master cylinders and slightly stronger rear differentials, and I think 87 on up had body mounted bumpers as opposed to frame mounted ones. Those are the MAIN differences, besides some minor cosmetic changes. Oh and there was a turbo 22re model from 86 and 87, but they all came with auto trannys which kills any power gains.
We're talking 1st gen 4Runers here, 1984-1989. Lots of differences in the newer ones.
97 4R, stock, daily driver
Re: Solid front axle [Re: Scorpion1971] #638893 08/20/05 06:44 PM
Thanks Adam, now on your runner you did the SAS conversion, was it expensive, and hard to do for the weekend garage project.
1988 4 Runner
Re: Solid front axle [Re: Scorpion1971] #638894 08/20/05 06:47 PM
Adam F Offline
Depends on what you consider expensive. It's going to cost you more than a few hundred dollars, but considering your changing out the entire front suspension and steering setup, it's relativly cheap. Look to spend maybe 2-4 grand depending on if you have to buy tires, gears, lockers, and stuff like that.
It's really quite simple. If you have a welder and a cutting torch, your set. That is the only "difficult" part of the job. I had a friend do the cutting and welding, and I bolted everything up myself in one weekend.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6007 MB (Peak: 0.6567 MB) Data Comp: Off Server Time: 2026-06-07 05:49:25 UTC
