Page 2 of 7 1 2 3 4 5 6 7
Re: Fuel Economy [Re: 52degrees] #639297 08/23/05 04:21 PM
IdahoJack Offline
Here is my favorite website for comparing fuel economy of different years, makes, and models. Gives you a good reference point of what your vehicle should get according to the government tests. http://www.fueleconomy.gov/feg/findacar.htm
90 Montero, 2dr, AT, V6, LSD, AC, KYB shocks, bouncy seat, 182K miles, JDM engine, 87 Starion seats, tow hitch
http://www.geocities.com/idahojack03/Index
Re: Fuel Economy [Re: kdogg] #639298 08/23/05 04:25 PM
grass13 Offline
1. approx. 380 miles per tank mix of hwy, city and stop & go.
2. between 18 & 20 gallons of regular unleaded.
3. 3.0L V6 SOHC
4. 32X11.5XR15 aggressive a/t, at recommended freeway psi.
5. 90' LWB engine, running gear and auto tranny. 89' LWB electronics & body.
6. Still pending...
Re: Fuel Economy [Re: kdogg] #639299 08/23/05 04:29 PM
Now do all of them mesuarmentes in metric! <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Fuel Economy [Re: kdogg] #639300 08/23/05 04:49 PM
bretwalda Offline
2, 19.7
3, 3.5L V6
4, 265/75/15
5, 1995 Montero SR
6, N/A
All city driving. So it's about 16 mpg. I don't think that's bad for a 7 passenger, 10 year old, 100K mile SUV. The only thing that gets me is the large tank and the ~$50 fill up.
$60+ here <img src="/forums/images/graemlins/barf.gif" alt="" /> Your stats give me hope that once I fix my vaccuum problems with the lower plenum and alignment I'll get more mileage out of this car...
1. 287 mi (actual)
2. 21.?
3. 3.5LDOHC
4. 285/75R16 (30PSI)
5. 95SR
6. Lifted 2.5", ARB roof rack, Overhead plenum problems (currently unplugged), messed up alignment
concreteprinter.com
Re: Fuel Economy [Re: 52degrees] #639301 08/23/05 05:10 PM
BobShaw Offline
87 Dodge Raider
15? gallon tank
20.5 mpg highway
3.5 gallons a day off road.
4.3 TBI engine and 700R4 tranny with 2.73 Tcase.
Bob Shaw
Re: Fuel Economy [Re: DRaider90] #639302 08/23/05 05:19 PM
powerRam50 Offline
before i got the carb rebiult i was getting about 22 to 23 but the secondary was shot.now i am getting 19 to 20 but i like to hot rod.i think regearing help me to keep ok mpg.also the truck is pretty light.
Re: Fuel Economy [Re: 52degrees] #639303 08/23/05 05:45 PM
W
Winston Offline
Please include:
1, 393
2, 20.7
3, 3.0L 24V SOHC
4, 235/75 15
5, 1995 Montero LS, Auto with Lock-up Torque Converter.
6, 153,000 miles on car. 35-40psi in the tires.
I use this for a 25 mile each way commute. I get between 18 and 19.5 mpg.
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
Re: Fuel Economy [Re: 52degrees] #639304 08/24/05 08:05 AM
52degrees Offline OP
This is great so far.
Here's how it's shaping up so far:
GenI 3.0
20.3 manual
19.2 unknown
15.5 auto
20.? unknown
GenI 2.6
12.2 manual
12.1 manual
22.? auto
16.? manual
13.? manual
15.? manual
GenI 4.3
20.5 auto
GenII 3.5
16.? auto?
GenII 3.0
18.7 manual?
So far it looks like the EFI trucks are getting much better fuel ecomony.
I'm a little suprised that the smaller, lighter trucks with smaller engine are doing so poorly. I have to wonder if this is an accurate trend or if this is only because the only rigs posted have problems.
Please keep posting your results. Be sure to include actual miles and actual gallons used. Accuracy is key.
And keep posting even if you already have. We're looking for patterns here (and it's something the government didn't look at when they did their testing). <img src="/forums/images/graemlins/wink.gif" alt="" />
Clay
KG6VNX
Re: Fuel Economy [Re: Winston] #639305 08/24/05 03:27 PM
Kevin C Offline
Gen 1 4 cyl turbo TBI EFI.
City highway mostly city mix 14 to 16.
Highway at 70-75 mph 20 MPG.
Things that helped. Good 02 sensor, alignment with 0? camber, lockup auto, 34 psi in the BFG AT (31"s).
On a good running 2.6 carb motorwith a manual I got about the same results but I had stock tires. Check out the EP site for their tested results.
Kevin
Re: Fuel Economy [Re: Kevin C] #639306 08/25/05 01:33 AM
12.2 MPG?!?!
1, miles traveled per tank= 132.41
2, gallons used= 10.8
3, engine size= 3.0 12V
4, tire size= 31"
5, year and model= 1997 Montero GL Dakar SWB
6, other mods that may affect fuel economy= I'm pretty sure it has a smaller muffler than it should. When I'm not giving it gas I hear little explotions <img src="/forums/images/graemlins/scared.gif" alt="" />
Pleas see this post where I have more details about my poor mpg <img src="/forums/images/graemlins/scared.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6420 MB (Peak: 0.7509 MB) Data Comp: Off Server Time: 2026-06-10 01:55:36 UTC
