Re: Fuel Economy
[Re: Kevin C]
#639317
09/01/05 05:09 AM
I'm working up the Coeficient of Drag vs angle in my head, I'll get back to you in a few years <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Fuel Economy
[Re: LRJ4x4]
#639318
09/01/05 06:19 AM
I've got about a 1 1/2 inch drop to the rear. It was accidental, but it looks ok. The headlamps really need to be aimed down a little though.
431.0 miles 20.790 gallons $59.44 <img src="/forums/images/graemlins/barf.gif" alt="" /> <img src="/forums/images/graemlins/barf.gif" alt="" /> <img src="/forums/images/graemlins/barf.gif" alt="" />
20.73 mpg
Clay
KG6VNX
Re: Fuel Economy
[Re: Kevin C]
#639319
09/01/05 06:53 AM
Kevin, u might have a good point since Clay is getting better mpg tham I am even w/bigger tires...But there is more wind resistance created by air flow through the grill than windshield. I think the increased drag on a lowered front may be produced by greater downward pressure over the body of the vehicle and consequently greater tire friction/vehicle weight. Which also accounts for it riding somewhat better than a hay wagon now.
1989 Montero LS (sold) 1994 Cherokee Country bone stock
Re: Fuel Economy
[Re: v6lsmonty]
#639320
09/01/05 07:17 AM
A nose down tilt will also present more area.
Typicly more area gets you more drag.
There are a bunce of other factors but obvioulsy Clay is doing something right. I am curious what type of driving he is doing,is it mostly highway? How fast does he go? Tire brand and type, allignment settings etc.
Kevin
Re: Fuel Economy
[Re: Kevin C]
#639321
09/02/05 01:07 AM
New fuel economy for my truck is...
15.25 MPG on 91 unleaded fuel.
it was of time and the computer was throwing weird codes <img src="/forums/images/graemlins/zombie.gif" alt="" /> its still not awesome but it might also have something to do with Venezuelan gas quality. Way less regulations here <img src="/forums/images/graemlins/barf.gif" alt="" />.
1, miles traveled per tank= 172.74 2, gallons used= 11.3 3, engine size= 3.0 12V 4, tire size= 31" 5, year and model= 1997 Montero GL Dakar SWB 6, other mods that may affect fuel economy= I'm pretty sure it has a smaller muffler than it should.
Re: Fuel Economy
#639322
09/13/05 05:33 AM
445.8 miles 22.683 gallons
19.65 mpg
Had a couple of high speed runs and four gallons of questionable fuel this trip.
Unfourtunately, no wheeling.
Clay
KG6VNX
Re: Fuel Economy
[Re: 52degrees]
#639323
09/13/05 05:57 AM
With larger tires, you can go the same speed at a lower RPM. Would that help?
Re: Fuel Economy
#639324
09/13/05 06:28 AM
Depends on how much traffic you hit and how many hills. If I remember right Caracas is pretty hilly and traffic into and in the city can get very slow.
Is gas still prety cheap?
Kevin C
Re: Fuel Economy
[Re: 52degrees]
#639325
09/13/05 08:25 AM
1, miles traveled per tank--- I never fill up 2, gallons used---??? 3, engine size---2.6 Auto 4, tire size---31X10.5X15 5, year and model---1987 Montero SWB 6, other mods that may affect fuel economy--- the bouncy seat (that thing weighs a ton!)
I'm averaging 9+ mpg here in beautiful $3.05 regular Southern California.
LOOKING FOR A DIESEL TROOPER OR A MONTERO SR 89 Range Rover Hunter edition 4X4 87 VW Vanagon Syncro 4X4 87 Monty, SWB, 2.6, auto 4X4 (sold) 86 Jeep FSJ 360 auto 2" lift 4X4 (sold) 87 VW Jetta 300,000 miles & counting... not 4x4
Re: Fuel Economy
[Re: sparkem]
#639326
09/13/05 01:44 PM
With larger tires, you can go the same speed at a lower RPM. Would that help? My 87 had been getting 13+ at best lately (spring before tranny went) on 31s. I put 33s on about two weeks ago and have gone through two tanks. One at 16+ and one at 16-. So I would say yes to your question, in my case at least. I wonder how that would pan out in a 2.6 NA, as the turbo has little trouble turning the bigger tires. All of which has me really wanting to find out why I am/was getting 13MPG before. I should be able to get more like 16-17, which should then equate to close to 20 with the 33s. At that MPG, this thing could become my daily driver! <img src="/forums/images/graemlins/lol.gif" alt="" /> BTW, all numbers are adjusted for the odo being off due to not upgraded for non-235s.
