Page 2 of 3 1 2 3
Re: What Gears for 33" tire and Auto Trans? [Re: RockJock] #639623 08/23/05 01:03 AM
A
AZPetrak Offline OP
What are you 2 using as the stock tire size?
27" and I get 3.75
28" and I get 3.62
235/75R15 tire is 28.9inches
new tire / old tire * gear ratio = new gear ratio
(34.8(typ 35) / 28.9) * 3.07 = 3.7
for reference, same calc with 32.8 inch new tire(typ dia of 33 tires) comes out to a new ratio of 3.48, so 3.73 would be over gearing a little for 33s
2007 4x4 Tacoma Dbl Cab with TDR and rear locker - stock for now
2001 Wrangler Sport - sold
1998 Rodeo S 4x4 - traded in
Re: What Gears for 33" tire and Auto Trans? [Re: AZPetrak] #639624 08/23/05 02:00 AM
I'm assuming 27" stock tire diameter. I'm not using any formula, I am just using ratio's.
27/3.07 = 33/X solve it and you get 3.752222......
If you assume 28's
28/3.07 = 33/x you get about 3.62
This also works for tire size and gear ratio.
28/3.07 = X/3.73 x = 34.01ö 27Æs stock would be 32.8ö
I'm sure that's what rock jock is doing.
Sorry BJ, I just read your post to fast... and wrong. I though you meant bigger tires are harder to turn from size and weight difference not load and RPM differences....
The whole post is regarding the latter.
Carburetors loved going lean during the initial transition to the power system, then richened out once they were fully on it (hence the worse gas mileage). EFI is a lot more linear (not relying on a mechanical system for AFR) so that the transition stays fairly close to center adding a bit of gas mileage.
Re: What Gears for 33" tire and Auto Trans? #639625 08/23/05 02:28 AM
BigJim Offline
Ok Sunder you say: Carburetors loved going lean during the initial transition to the power system, then richened out once they were fully on it (hence the worse gas mileage). EFI is a lot more linear (not relying on a mechanical system for AFR) so that the transition stays fairly close to center adding a bit of gas mileage.
I have no quarrel with the fact that modern fuelies are much more sophisticated in what they do. HOWEVER the fact remains that adding a load, such as an incline or larger tires, will decrease the timing and increase the fuel to air ratio. Or am I incorrect? I cannot see how even a fuelie can maintain timing and mixture when adding a load.. For sure it would clatter and the EAR would retard the timing at that point.. does it not richen the mixture too?
Ps.. Did you mean ADDING a bit of gas milage?
Re: What Gears for 33" tire and Auto Trans? [Re: BigJim] #639626 08/23/05 02:36 AM
RockJock Offline
Sunder "I'm not using any formula, I am just using ratio's."
The formula he is using is the same you use to solve for x=gear ratio in your ratios. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: What Gears for 33" tire and Auto Trans? [Re: BigJim] #639627 08/23/05 03:01 AM
A
AZPetrak Offline OP
We are using the same formula. If you plug in your numbers
New Tire / old Tire * gear ratio = new gear
33 / 27 * 3.07 = 3.752
The difference is I am saying the stock tire P235/75R15 has a diameter of 28.9 inches, and the typical diameter of a 33 tire is more like 32.8 inches, so:
32.8 / 28.9 * 3.07 = 3.48
We are using the exact same math, just starting with different numbers.
So for 35s:
34.8 / 28.9 * 3.07 = 3.7
This means the 3.73:1 gear ratio would get me back to stock with 35 inch tires. I have 33 inch tires so I am over gearing a little.
I know that at 69MPH (using GPS) I am currently at 2200 RPM,using similar math, with 4.11 I will be just over 2900 RPM and with 3.73 gears I wil be around 2600 RPM at 69MPH.
Re: What Gears for 33" tire and Auto Trans? [Re: AZPetrak] #639628 08/23/05 03:51 AM
RockJock Offline
I usually figure from 27" as a stock tire. I think mine came with 205/75-15 or 27.1" I would have thought your 2001 came with either 215/75-15 (27.7") or 225/75-15 (28.3). I would still go with the 4.10 <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: What Gears for 33" tire and Auto Trans? [Re: AZPetrak] #639629 08/23/05 07:28 AM
Well, if your tire numbers are right, go with 3.73's. My experiance with 31's and 3.73's would tell me to go 4.10's and 33's.....
Re: What Gears for 33" tire and Auto Trans? #639630 08/23/05 12:05 PM
JeePete Offline
A friend is running 34" Super Swampers with 3.55 and his stock speedo is right on. That means his RPM's are running like stock also. Right? (his stock gears were 2.73's). My CJ with 3.31's and 32's (31.8" nominal dia. new) turns 2200 @ 60 (GPS) in 4th and I like it. At 60 my speedo reads 5mph slow. I get good mileage in 5th @1850 cruising about 65. I got no problem downshifting when I need more power. I always figured if I went to 33's i'd like 4.1's but only with overdrive. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: What Gears for 33" tire and Auto Trans? #639631 08/24/05 04:54 AM
Re: What Gears for 33" tire and Auto Trans? [Re: JeePete] #639632 08/24/05 10:08 PM
A
AZPetrak Offline OP
Well I decided on 4.10s. I just hope the D35 will give me a few years of service before I blow it up. I will have to start saving for a Ford8.8 now
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6327 MB (Peak: 0.7414 MB) Data Comp: Off Server Time: 2026-07-16 22:39:43 UTC
