I told you guys I'd be back
#639738
08/23/05 02:17 AM
Now that the tranfer case/ wheel issue is taken care of.... I have a generous condensation problem! I assume its from my AC ... but ... theres enough of it that when i moved my floor mat (passenger side) half the carpet is soggy! Uhg.... <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: I told you guys I'd be back
[Re: laughinwillow]
#639739
08/23/05 02:33 AM
Could be one of four things.. 1. The A/C is low on freon and iced up causing condensation to leak out of the cabnet when it melted.
2. Your condensation hose is holy or not attached anymore.
3. Your heater core is faulty and that is coolant on the floor.
4. It has been raining and that is rain water. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#639740
08/23/05 02:51 AM
Does it drip alot of water under the Jeep when running with the AC on? If not prolly 2 if so prolly not 2.
Does it smell of antifreeze? If yes prolly 3 if not prolly not 3.
Has it been raining? If yes prolly 4 if not prolly not 4.
<img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: RockJock]
#639741
08/23/05 02:58 AM
does not smell of coolant .. and feels like water (i touched) and put a white paper napkin on it .. its water to be assumed ... no rain ... when the AC is running theres a little drip.
[Re: laughinwillow]
#639742
08/23/05 03:05 AM
The drip is under the front console on the passenger side ... one part of the guts up under the dash is quite hot while next to it is very cold.... errr ... sounds like i'm screwed for something ... lol <img src="/forums/images/graemlins/angry.gif" alt="" />
[Re: laughinwillow]
#639743
08/23/05 03:59 AM
I would find the factory AC drain and make sure it is still connected. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: RockJock]
#639744
08/23/05 04:01 AM
thank you <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: laughinwillow]
#639745
08/24/05 02:16 AM
Administrator
Yes, it's the AC drain. Likely plugged. It goes through the firewall just below the evaporator.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6192 MB (Peak: 0.6973 MB) Data Comp: Off Server Time: 2026-06-23 12:01:35 UTCValid HTML 5 and Valid CSS
