Page 3 of 4 1 2 3 4
Re: 1 piece drive shaft [Re: paulevans76] #639970 08/24/05 04:33 AM
barak Offline
So a one piece drive shaft from a manual won't work with an auto because I have a fixed and they have a slip yoke.
Re: 1 piece drive shaft [Re: paulevans76] #639971 08/24/05 06:41 AM
maxwell417 Offline
My 89RS Trooper 5spd and 88 Trooper 4dr 2.6 5spd both have slip-joints. 90 Trooper v6 at is fixed.
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: 1 piece drive shaft [Re: maxwell417] #639972 08/24/05 01:22 PM
1
1jackleg Offline OP
<img src="/forums/images/graemlins/lol.gif" alt="" /> Yeah, fixed at both ends and slip in the middle.
another 42.5" dimension. I'll try to get it done Saturday morning if they are open. I'll post my measurement for reference.
I really don't want to drive 45 minutes at 65 mph in FWD <img src="/forums/images/graemlins/notooth.gif" alt="" />. Might tear a boot <img src="/forums/images/graemlins/shiner.gif" alt="" />. I'll drive the school bus. Plenty of room to tote the shaft in there <img src="/forums/images/graemlins/wink.gif" alt="" />
Thanks Fellas - JL <img src="/forums/images/graemlins/cheers.gif" alt="" />
I ain't real bright...
1990 Trooper LS, V6, Auto, 4door
132,000 miles 11/26/09
Re: 1 piece drive shaft [Re: 1jackleg] #639973 08/24/05 01:57 PM
RobG Offline
the isuzu tcase/tranny doesn't mind. I drove highway speeds for 5 hours on my front shaft to wheel at Tellico because my rear shaft produced too many vibes for highway travel.
Of course, I had a SAS at the time, so i can't say about CV boots, but unless they're already dead, they should easily last a single trip like that without incident.
-Rob
Re: 1 piece drive shaft [Re: RobG] #639974 08/24/05 07:22 PM
matthew Offline
all you need to do is remove seperater the 2 shafts at the 2nd u-joint in the carrier bearing, take the front yoke...press it on the u-joint of the back 1/2 of the shaft.
then that is your new shaft.
that will need to be re-tubed to length
disguard the part with the carrier bearing in it.
FYI, you can press out the front u-joint and save it as a spare for the new shaft.
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: 1 piece drive shaft [Re: 1jackleg] #639975 08/25/05 12:24 AM
barak Offline
Well , I was curious , and had to do it anyway , so I went out and took off the driveshaft on my 89 with the 2.6.I was surprised , its a fixed yoke also , with a total length of 44" , so a little longer than the 2.8 driveshaft.Of course we are talking from end to end with the u-joints and bearing in there , not just the length of the shafts alone.So maybe I can just take in my 2.6 shaft , tell them the length I need and have them do it.Although I am not sure what length I need yet <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 1 piece drive shaft [Re: barak] #639976 08/25/05 02:33 AM
paulevans76 Offline
barak are you auto?
88 Troop - Posing yard art
Re: 1 piece drive shaft [Re: paulevans76] #639977 08/25/05 02:51 AM
barak Offline
Yup , the 89 2.6 and the 90 2.8 are both autos.
Re: 1 piece drive shaft [Re: barak] #639978 08/25/05 01:09 PM
1
1jackleg Offline OP
Saturday ain't lookin' good. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Ahh well, I'll get to it sometime. - JL <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: 1 piece drive shaft [Re: 1jackleg] #639979 08/25/05 02:33 PM
paulevans76 Offline
OK if anyone out there has a 1st gen trooper with a manual tranny and a fixed yoke t-case, post up with more info about your truck.
My guess is that there's noone out there <img src="/forums/images/graemlins/notooth.gif" alt="" />
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6456 MB (Peak: 0.7509 MB) Data Comp: Off Server Time: 2026-05-29 15:43:34 UTC
