Re: 5.29 gears noticeable improvement off-road?
[Re: LandRaider]
#640102
08/25/05 07:47 AM
I believe Dat did this past Sierra Challenge. We believe it was due to the improper install of his front IFS lift.
I know Lloyd's stripped the splines on his half shafts but that's not the CVs.
[Re: off-roader]
#640103
08/25/05 02:48 PM
The stripped splines were from side gears machined wrong on the first Detroit, and had nothing to do with failure. All 4 of mine have been shattered cages. Dat actually broke one outter cage and one inner cup. While the inner cup is new to me, its common on Toyotas. I plan to look at that as well, as it could be the next weak link.
[Re: Lloyd Swartz]
#640104
08/25/05 04:39 PM
man, I sure hope I can avoid all this carnage by sticking in my own neighborhood where we dont really have rocks... just a lot of mud and loose dirt.
1986 Montero 2.6l 31X10.5 BFG MT - Weber carb with custom intake Rear LSD - RCI seats - Oil cooler - Manual hubs Custom bumpers front and rear + rock sliders
[Re: DanWheeler]
#640105
08/25/05 06:11 PM
man, I sure hope I can avoid all this carnage by sticking in my own neighborhood where we dont really have rocks... just a lot of mud and loose dirt. Actually carnage is MUCHHHHH worse up there! The mud means full throttle applications all the time and the = breakage. From what I have gathered the best trails combine rocks and mud <img src="/forums/images/graemlins/scared.gif" alt="" /> Its why you see some east coast guys breaking without any major mods even, such as Captain Nemo.
[Re: Lloyd Swartz]
#640106
08/25/05 07:00 PM
the cv's are pretty buff.i am running 35's and a welded front and wheel hard and have not broken a cv yet.they have been clicking for over a year also.it does not mean i wont break it but i have seen lots of toy's with birfield's that were blown to bits.i do think some 5.29's would be nice.what is the current price.
[Re: powerRam50]
#640107
08/25/05 07:02 PM
i'll PM you with Frank Zanetti's email addy
[Re: DanWheeler]
#640108
08/25/05 11:37 PM
Just to clarify a couple of things. I can get every part no of 5.29's but I honestly don't recommend fitment to the Gen 1 4 cylinder front (7.25" diff). My advice is to upgrade to the Gen 1 3.0 V6 front diff & CV's and use the 8" 5.29. Joe did this upgrade and used the 8" 5.29 for the front and rear now he can also run the new ARB front locker. You will have a much stronger front end as a result. The small front 5.29 is a downgrade in strength and broken much easier than the 8" unit. In fact over here no-one has actually managed to break a 8" 5.29 but plenty of the 7.25" have been. The 7.25" is also more expensive than the 8" for some reason by about $70. In terms of improvement you will notice it more onroad especially with an auto running 33"s which had 4.625 diffs. It is a good upgrade as Lloyd said. I noticed the difference in mine going up from 4.88's it improved onroad driveability but still doesn't substitute for lack of power running 35"s on a heavy lwb with a 3.0 V6. Offroad I did notice slightly deeper gearing in low range. I can also say that the 8" 5.29 C&P is MUCH stronger than the Toyo version I have in the front of my truck with the SAS. The ring gear is way thicker along with the pinion gear. It would take something obscene to bust one of these <img src="/forums/images/graemlins/notooth.gif" alt="" />
I just luv my "clacker Jabber".................
[Re: Mister Bishi]
#640109
08/25/05 11:46 PM
i'm definitely going 8" in the front for strength and ARB RD110. I've got my hand impact wrench and 8mm hex key ready to go - just need to find a V6 this weekend in the junkyard.
[Re: DanWheeler]
#640110
08/26/05 12:34 AM
How much is the 8" gears and 2.85 T-case gears in $ and where do they ship from?
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
[Re: PartyTruck]
#640111
08/26/05 01:40 AM
Not sure current prices US, but I think like 800 for t/case gears and 900 for ring and pinons. They ship from the fine mates in Melbourne, Victoria, Australia.
