Engine upgrade for 1988 Trooper #640283 08/24/05 04:24 PM
I have a 1988 Isuzu Trooper with the 2.6 and an auto tranny. I would like more power, but can't decide on what size of engine to go with. Anyone that has tackled this problem please give me some ideas. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Engine upgrade for 1988 Trooper #640284 08/24/05 04:59 PM
Richard Saylor Offline
Without doing an entire driveline swap, you've got the most powerful engine that'll bolt up to your transmission. If doing a driveline swap, then it's up to your imagination, fab skills, and wallet. The 2.6 is a good little motor. Very torquey. It can be built up to run pretty good. Check out houlster's website, www.houlster.com, and you'll see what can be done with forced induction.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Engine upgrade for 1988 Trooper [Re: Richard Saylor] #640285 08/24/05 08:04 PM
You're right in that the 2.6 is a good little engine. It should serve my needs. I'm just looking to do a little mudding. What size tires would you recommend considering it has no lift kit or would you stay with the stock tires?
Re: Engine upgrade for 1988 Trooper #640286 08/24/05 08:21 PM
CPOM Offline
I would reccommend 38s and just cutting all the metal that rubs
CHRIS
98 Amigo, 92 Pup
Re: Engine upgrade for 1988 Trooper [Re: CPOM] #640287 08/24/05 08:30 PM
Will the 2.6 turn the 38's without putting a lot of strain on the drivetrain?
Re: Engine upgrade for 1988 Trooper #640288 08/24/05 08:48 PM
Jim_Paget Offline
I think that Chris was pulling your leg without using any graemlins.
While 38s might be optimal for mudding, there is no way that your stock front-end would stand up to the abuse.
Realistically, anything bigger than 33s is really pushing the envelope for your IFS.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Engine upgrade for 1988 Trooper [Re: Jim_Paget] #640289 08/25/05 10:11 AM
I'm new to this, but thought that sounded kind of extreme. But, I'm glad he got a good laugh and I learned something.
Re: Engine upgrade for 1988 Trooper #640290 08/25/05 01:11 PM
Jim_Paget Offline
Mudnut
On this site, do not direct that graemlin at other people directly. I have edited your post.
Jim Paget
www.rrr4x4.com
Re: Engine upgrade for 1988 Trooper [Re: Jim_Paget] #640291 08/25/05 02:54 PM
Sorry about that, I wasn't thinking. It was meant to be in good nature.
Re: Engine upgrade for 1988 Trooper #640292 08/27/05 05:49 AM
You can swap the bellhousing for a Jeep for the 2.5 and 4.0 or for a Toyota piece for the 22r/re
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.010s) Memory: 0.6267 MB (Peak: 0.7320 MB) Data Comp: Off Server Time: 2026-11-18 11:33:44 UTC
