Trooper wiring gurus needed #640370 08/24/05 10:19 PM
A
acy76 Offline OP
Hello all -- I've been busy converting my 88 Trooper to diesel (details and links here: 4x4 wire thread ) and I'm currently involved in the wiring. I've decided to remove all the unnecessary wiring to clean the engine bay up and simplify the vehicle. I am wondering about a couple of things:
1) Does the ECU control anything other than engine management? As in, can I remove the ECU and harness and not affect any other subsystems?
2) What is the best source for a comprehensive wiring diagram for this vehicle? I've got the Haynes manual already.
Thanks.
1988 Isuzu Trooper LS
2.8l Isuzu 4JB1-TC intercooled turbo diesel
www.dieseltrooper.blogspot.com
Re: Trooper wiring gurus needed [Re: acy76] #640371 08/24/05 10:33 PM
A
acy76 Offline OP
I should add that I've found a used 91 Trooper electrical factory manual - is this sufficiently similar to the 1988 that I could use it?
Re: Trooper wiring gurus needed [Re: acy76] #640372 08/26/05 02:12 AM
thecure7 Offline
It should be. I believe the 88-91 should be the same. 87 Prior is different if I am not mistaken. Someone chime in and correct me if I am wrong...
1992 Land Rover Range Rover 3.9L V8
1995 Honda Passport V6 4x4
1989 Isuzu Trooper 2.8L V6 Manual ~Sold
Re: Trooper wiring gurus needed [Re: thecure7] #640373 08/26/05 03:30 AM
barak Offline
Ok guys , heres some goodies from my alldata cd's.It has the 2.6 and 2.8 engine wiring and chasis wiring from 88-91.
They are sitting on my site if anyone wants the link to them also to grab them.Hope it helps everyone out <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Trooper wiring gurus needed [Re: barak] #640374 08/26/05 04:00 AM
thecure7 Offline
Sweet man, that is perfect! Hope it helps him out! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Trooper wiring gurus needed [Re: thecure7] #640375 08/28/05 02:51 AM
A
acy76 Offline OP
Thanks for the diagrams. For everyone who has only the Haynes manual, grab these as they're worlds better.
I still went ahead and ordered the ETM for the 1988 model, but these got me much farther than I would have gotten with only the Haynes.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6095 MB (Peak: 0.6966 MB) Data Comp: Off Server Time: 2026-06-08 13:18:10 UTC
