Brake caliper piston problem #641440 08/27/05 11:25 PM
W
Wildcat_4R Offline OP
I am in the process of changing the brake pads on my 87 4-Runner. It has the S12+12 calipers (4WD IFS 4-piston). I got the driver's side completed so far. However, the top front piston on the passenger's side will not go back into the caliper. It moved in only a fraction of an inch and will not move any further. The other 3 went in fine. I tried removing brake fluid from the system and then tried taking the caliper off and using a C-clamp however that did not work either. I pulled the cylinder boot and set ring and tried to remove the piston but I can't figure out a good way to pull it out. Any information on this subject would be greatly appreciated. Anyone have any experience rebuilding these calipers? This happen to anyone else? I need this thing back on the road by tomorrow.
1987 4-Runner with a "slightly modified" 22RE
Re: Brake caliper piston problem [Re: Wildcat_4R] #641441 08/27/05 11:48 PM
Esquire812 Offline
Got an air compressor? I rebuilt my 88's brakes this last winter and I used air to force the pistons from the bores. When it was down to just one being stuck...things got interesting- but with some penetrant and about 100 PSI and the other pistons clamped inplace it finally came out.
I'll never buy a caliper again after realizing how easy they are to rebuild. Only about $8 per kit available at almost all parts stores.
Watch your fingers when doing this...broken finger tips hurt!
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: Brake caliper piston problem [Re: Esquire812] #641442 08/28/05 12:00 AM
W
do you just hook up the air where the brake line connects?
Re: Brake caliper piston problem [Re: Wildcat_4R] #641443 08/28/05 12:30 AM
xrtim Offline
Yea, use air pressure, but put something soft in the caliper where the piston is going to be fired into so you don't damage it. Whenever I've done this in the past I've just popped them out with hydraulic pressure. You probably have that piston slightly cocked in the bore, hopefully you didn't groove it.POC <img src="/forums/images/graemlins/patriot.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5998 MB (Peak: 0.6560 MB) Data Comp: Off Server Time: 2026-06-07 11:07:06 UTC
