Re: Toyota Calipers [Re: foxtrapper] #642666 09/01/05 02:52 PM
87Toy4x4 Offline
the ones w/ the 4 big pistons are the v6 version, correct? do they brake a lot better than the other ones?
Re: Toyota Calipers [Re: OOP'S] #642667 09/01/05 03:38 PM
DRTDEVL Offline
All 4x4's had four piston calipers. If you can, get the calipers with the four big pistons.
I could have sworn mine had 2 pistons... <img src="/forums/images/graemlins/confused.gif" alt="" /> I'll have to look at that when I start all my final maintenance before shipping it to Europe.
Re: Toyota Calipers [Re: 87Toy4x4] #642668 09/01/05 04:24 PM
the V6 version has four equal size(larger) pistons. they provide greater clamping force on the rotor. you may want to change you master cyl to the larger 1" bore(also from V6) to give the pedal a firmer feel.
I'm running V6 calipers on my '85 with rear disk w/ small calipers(grand prix) along with a V6 booster/ master cyl. the pedal feels about the same as it did with stock brakes. but the truck definatley stops much better and I running 35" tires.............Karl
Re: Toyota Calipers #642669 09/01/05 11:26 PM
dknight Offline
I rebuilt my calipers using the toyota kit. I did both sides for the cost of one reman caliper. Was pretty easy (once I got the stuck pistons out - tip I used a thin piece of wood in place of the brake pad, then let the power brakes bust the siezed pistons loose before I removed the calipers from the truck.)
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6046 MB (Peak: 0.6633 MB) Data Comp: Off Server Time: 2026-06-07 03:21:02 UTC
