Zuk !! Step up for pinion???'s #644093 09/06/05 01:47 AM
solarcrew Offline OP
<img src="/forums/images/graemlins/confused.gif" alt="" />I was looking on the net for master bearing kits for 8" 4.56 and 7.5" 4.56 ring and pinion install.I believe it was on Randy's R&P and Precision Gear that they showed 2 different sizes for the 8" rear.By the way,this is a 22re,5-speed with stock 4.10's.OK,back to the ??'s.They show an 8"(A) 1-1/2 diameter,8"(B) 1-5/8 diameter.I'm guessing this is the pinion shaft size.The 7.5 front only had 1 listing but it didn't say what the diameter was.What size should go into the 4 cyl and why are there 2 different sizes?The reason I'm asking is because I'm buying front and rear 4.56 ring and pinion from a private party.Thanks for any help! <img src="/forums/images/graemlins/cheers.gif" alt="" />
87'4runner-22re,5spd
Re: Zuk !! Step up for pinion???'s [Re: solarcrew] #644094 09/06/05 06:48 AM
ZUK Offline
The 1.5" pinion(length of the pinion head) is for 79~85 trucks.....the 1.625" pinion is for 86~95ish trucks....your 87 wants that one. <img src="/forums/images/graemlins/cheers.gif" alt="" />
mostly stock
Re: Zuk !! Step up for pinion???'s [Re: ZUK] #644095 09/06/05 02:49 PM
ZUK Offline
another thing.....the long pinion head(1.625") is usually more money and harder to find.....there is nothing wrong with using the short pinion head in your 87 with a larger pinion shim pack(~.240").....I would.
mostly stock
Re: Zuk !! Step up for pinion???'s [Re: ZUK] #644096 09/06/05 07:35 PM
<img src="/forums/images/graemlins/kewl.gif" alt="" />Thanks Zuk,that's what I needed to know! <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.009s) Memory: 0.6009 MB (Peak: 0.6570 MB) Data Comp: Off Server Time: 2026-11-04 13:42:07 UTC
