Page 1 of 9 1 2 3 4 5 6 7 8 9
Steering rod recall #644901 09/08/05 02:59 AM
kewlynx Offline OP
More fun to go with the balljoint recall...
Sticky requested please
Here is the literature from www.nhtsa.gov
Manufacturer : TOYOTA MOTOR NORTH AMERICA, INC.
NHTSA CAMPAIGN ID Number : 05V389000 Mfg's Report Date : SEP 06, 2005
Component: STEERING:LINKAGES:ROD:RELAY:CONNECTING
Potential Number Of Units Affected : 977839
Summary:
ON CERTAIN PICKUP TRUCKS AND SPORT UTILITY VEHICLES, IF THE STEERING WHEEL IS REPEATEDLY TURNED UNDER CERTAIN CONDITIONS WHERE HIGH STEERING EFFORT AND POWER ASSIST ARE REQUIRED, FOR INSTANCE, WHEN FULLY TURNING THE WHEEL WHILE THE VEHICLE IS STOPPED, A FATIGUE CRACK MAY DEVELOP IN THE STEERING RELAY ROD.
Consequence:
IF THE VEHICLE IS CONTINUED TO BE OPERATED IN THIS CONDITION, THE RELAY ROD MAY FRACTURE, INCREASING THE RISK OF A CRASH.
Remedy:
DEALERS WILL REPLACE THE STEERING RELAY ROD. THE RECALL IS EXPECTED TO BEGIN DURING LATE SEPTEMBER 2005. OWNERS SHOULD CONTACT TOYOTA AT 1-800-331-4331.
Notes:
CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
AFFECTED VEHICLES
Make / Models : Model/Build Years:
TOYOTA / 4 RUNNER 1989-1995
TOYOTA / PICKUP 1989-1995
TOYOTA / T100 1993-1998
**ubi apis- ibi salus**
Re: Steering rod recall [Re: kewlynx] #644902 09/08/05 08:09 PM
mt_goat Offline
Anyone out there ever seen or heard of one of these rods breaking?
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: Steering rod recall [Re: mt_goat] #644903 09/09/05 01:28 AM
kewlynx Offline OP
Seems the Taco and T100 bunch have issues. I believe Chili Man is one of them.
Must be a few out there, otherwise there wouldn't be a recall.
Re: Steering rod recall [Re: kewlynx] #644904 09/09/05 04:10 PM
Red_Chili Offline
Toyota Section Staffer
My Taco has a tragic rack and pinion issue (excess vertical play in the rack rod itself, the bushings are worn, driver's side). But this is news to me. Just what exactly is a 'steering relay rod'? The shaft extending from steering wheel to steering box? Or the middle part of the IFS tie rod, which in my case has been made into a barbeque or Chevy or something by now?
Doesn't extend back to my 87, eh?
-Bill
Re: Steering rod recall [Re: kewlynx] #644905 09/09/05 08:25 PM
Monty n Guate Offline
My steering rod broke about 1 and a half ago. It broke right below the steering box arm. I wasn't doing anything crazy in it. Downtown driving! I went around a curve and SNAP! <img src="/forums/images/graemlins/zombie.gif" alt="" /> Luckily I wasn't going fast when it happened. Losing your steering is never a fun thing to do. Anyway I put another one on it and no problems to date.
Don Iler
97 4cyl. Tacoma
OME 881s, N91s, Alcan AALs, Rancho 9k rear shocks
4.56 gears
32x11.50 Procomp ATs
Re: Steering rod recall [Re: Monty n Guate] #644906 09/09/05 09:42 PM
mt_goat Offline
Below the steering box? The only thing I have below the steering box is the pitman arm, are you talking about the output shaft the pitman arm attaches to maybe? That thing is huge???? Maybe you are talking about the center link that links the pitman and idler arms together?
Re: Steering rod recall [Re: mt_goat] #644907 09/09/05 10:08 PM
mt_goat Offline
Ok, I think I figured it out. The FSM calls the center link the "Relay Rod". If that's the case mine is in the trash somewhere already, my Superlift kit replaced that factory part 7 years ago.
Here's the page in the FSM: http://personal.utulsa.edu/~nathan-buchanan/93fsm/steering/16steer0.pdf
Re: Steering rod recall [Re: mt_goat] #644908 09/09/05 10:27 PM
mt_goat Offline
Anyone getting this "relay rod" replaced on the recall should insist on a free alignment afterward.
The dealers will probably try to sell you new tie rods while they are doing the recall. Get them if you need them, if it were me I'd replace mine first, then go in and have the "relay rod" replaced and get a free alignment.
Re: Steering rod recall [Re: mt_goat] #644909 09/10/05 02:02 AM
Snowtoy Offline
If it is the centerlink(should find out tommarrow), mine broke over the 4th of July weekend. I posted a pics here Broken Centerlink Fortunately it broke at the beginning of the trail(about 2hrs from town), and not on the way getting there(plenty of turns and high cliffs). After cleaning it up, I could see where it had fractured in the past, about 1/3 of the steeel was aged compared to the new break. There was an identical break on a 4-Runner a the wrecking yard where I scavenged another centerlink(relay rod), howvere the owner of it wasn't as lucky as I, the whole right side was crushed where it rolled.
Re: Steering rod recall [Re: mt_goat] #644910 09/10/05 03:29 AM
ldivinag Offline
lol.... exactly...
replacing all of my tie rod ends, idler arm and pitarm soon....
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
PHP: 7.4.33 Page Time: 0.017s Queries: 16 (0.013s) Memory: 0.6459 MB (Peak: 0.7710 MB) Data Comp: Off Server Time: 2026-11-14 00:36:42 UTC
