Page 4 of 9 1 2 3 4 5 6 7 8 9
Re: "ROKIA" [Re: DamKia] #645359 09/22/05 01:53 PM
Dave Scott Offline
that's pretty much what we're banking on, gary. speaking of banking- in order to get started on those, all i need is a t-case and some first-run cash.
morgan, i've seen the SAS-ed Sportages from across the pacific, and here's what i have to say- i've seen about 4, maybe 5 done in both Korea and Malaysia, combined, but if you pay close attention, it's booty-fab. bad weld jobs, link designs not very well thought out and leaf designs i wouldn't want to be anywhere near. but yeah, they got it done first, but then again, they've had Sportages over there since at least 1992. <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: "ROKIA" [Re: Dave Scott] #645360 09/22/05 03:10 PM
DamKia Offline
Kia Moderator
The Buick 3.8 liter with T700 4L60E tranny with a Tacoma tcase should be where you guys are heading. Engine is about 2" shorter than the Kia (= electric cooling) and the tacoma gear driven Tcase can be geared down to 5:1 if you really want.
Just had the two diffs hoisted into my car last night. Heavy!!!!!!! <img src="/forums/images/graemlins/scared.gif" alt="" /> (~300lb rear + 350lb front)
Re: "ROKIA" [Re: DamKia] #645361 09/22/05 06:20 PM
sportagebandit Offline
why not go with a 4.3 v6 like out of a blazer or s-10 p/u?
i changed my s-10 fom fuel injection over to carb.eldebrock makes an intake manifold. i also installed a msd distributor, coil, and 6a ignition box so no need for computer.from my understanding is that the 700r4 trans is also stronger and has a lower ratio for 1st and 2nd gear. <img src="/forums/images/graemlins/kewl.gif" alt="" />then you can go with an aftermarket transfer case and pretty much run whatever gear you want.
96 SPORTAGE 4 DOOR:1 3/8 body lift:eibach springs & spacers:15x8 rockcrawlers & 31x11.50 super swampers:warn hubs:winch bumper http://www.cardomain.com/ride/2115301
Re: "ROKIA" [Re: Dave Scott] #645362 09/22/05 07:06 PM
MorganEstill Offline
I noticed that, too. They're like the rednecks of Asia. <img src="/forums/images/graemlins/shiner.gif" alt="" />
I figure all I need is a cheap welder, a grinder, and a couple of axles and I'd have at least as good as the Sportage over seas. (well... I guess I don't really need the grinder - booger welds are tha shiznit is Asia.)
'97 Sportage, 4" Lift 1" BL, 31" BAJA CLAWS, Rallye 4000s, Line-Xed Hood, Grille, K&N, 2.25" Exhaust, RS9000s, GPS...
"What is IFS and where can I get some??" (outerlimits4x4.com)
Re: "ROKIA" [Re: MorganEstill] #645363 09/22/05 10:48 PM
i am seriously considering purchasing a sportage witha blown motor at my dads shop for like a hundred bucks and doing the engine, tranny, tranfer case, and diff swap. Dave and Rob how long have you been working on yours? i know daves is a daily driver. 4.3 and 700r4 out of my s-10. any ideas on transfer case and diffs?
Re: "ROKIA" [Re: KIAFREEKROB] #645364 09/22/05 10:56 PM
Check this out = with the 5:71's & 35's it has a little lower than stock gearing.
How did you calculate that, Rob? Every time I've calculated that, I've discovered that the 5.71s would be under-geared compared to stock (i.e.: less torque, higher crawl ratio.) That was one of the main reasons I am not seriously considering Yota axles for an SAS on the Sportage, that, and they're a bit too narrow and I wouldn't want to spend the $$$ to widen it.
Re: "ROKIA" [Re: Dave Scott] #645365 09/22/05 11:31 PM
mattnsteph Offline
Hey Dave and Rob something maybe for you to look into for gearing not sure but ya never know. Suzuki is making a 2.0 adapter kit for the samurai trans and transfer case. Now before yall get excited this is the suzuki 2.0 maybe worth checking into seeing how you can now get 8:1 gears for the samurai tansfer case. Here is the link:
http://www.rocky-road.com/zukworks.html
Or something like this...
http://www.pirate4x4.com/forum/showthread.php?t=395083
In midst of building.
Re: "ROKIA" [Re: mattnsteph] #645366 09/23/05 02:22 AM
Keep in mind guys, low axle gears and extra low t-case gears, like the 8:1's loose alot of strength, it's okay in a light a$$ sammy buy most sportages have a lil more to them.
As far as ease, I feel it would be easier from a fab standpoint to swap in a two-wheel drive tranny, and use an OTT divorce adapter for a toyota t-case or dual t-case, and a super short shaft between the 2wd tranny and t-case and you've got pretty much a stock drivetrain and don't have to go through the hastle of wiring, fuel, cab mods, just fab up a cross member, some remote shifting linkages and you're there...
Re: "ROKIA" [Re: DamKia] #645367 09/23/05 04:25 AM
KIAFREEKROB Offline OP
Agreed, but It dont hurt to dream.
How bout a Chevy V6 - B&M Blower - T18 - Atlas twin stick 4:1?
That sould get not only way low but with twice more + power.
I suppose I should wait to kill the stock motor 1st = only got 17400 miles on it. Plus another 10 or 15k of funds. Not gunna max out my credit cards.
It's all paid for @ somewhere around 40k invested, counting the cost of the Rig brand new for 14k / not counting Labor of course. Prolly in the 300 hour range into it.
Some people are <img src="/forums/images/graemlins/zombie.gif" alt="" /> SICK!
Why go around? When You can go over!
Re: "ROKIA" [Re: mattnsteph] #645368 09/23/05 04:40 AM
Thought about that = Would have to run a 2WD trans - Then a stubby shaft to the T-Case. The biggest problem it ya would have to 86 the fuel tank cause the Sammy T-Case rear output is offset to the rt more than the Kia = I allreddy knocked off the rear D-Line balance weights on the 1st shakedown from hittin the tank = Hammertime for clearance.
I seen the 8:1 = Awesome!
Then @ least in my Rig the rear D-line would be real short. Too short.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6474 MB (Peak: 0.7584 MB) Data Comp: Off Server Time: 2026-06-23 13:01:46 UTC
