Page 5 of 9 1 2 3 4 5 6 7 8 9
Re: "ROKIA" #645369 09/23/05 04:45 AM
KIAFREEKROB Offline OP
This would work easier in the 4 door = not the 2 door, <img src="/forums/images/graemlins/frown.gif" alt="" />
Might work in a 4 door?
I seen the double T-Case set up = Insane and perfect = I think it puts ya into the 200:1 krawl range.
Why go around? When You can go over!
Re: "ROKIA" [Re: KIAFREEKROB] #645370 09/23/05 01:44 PM
Dave Scott Offline
ok, right, 5.71's will only get you close to stock rpms. rob, what prolly happened in your case is that you were running those boggers for a while and got used to the gearing "feel" and then swapped axles and now you can feel the lower gearing and you feel like it's lower than you remember the stock gears being, but it isn't as far as rpm's are concerned.
the correct gears for a 35" tire for our Sportages would be around 6.20:1. for a 33- 5.88:1.
dual case has been discussed, and it would not be possible in the 2-door without removing the tank and running a fuel cell in the cargo area or beneath it behind the rear axle.
the best option to swap t-cases is to run the 2wd tail housing on the tranny and a jack-shaft with any t-case you want. all has to be fabbed unless you get a specific kit for a specific t-case, then you still have to fab the Kia end.
brainstorming is always a good thing, but occasionally, it's been thunk 'til it can't be thunk anymore. <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: "ROKIA" [Re: Dave Scott] #645371 09/24/05 03:30 AM
I didn't think about the running the 31's 4 ever = the Rig feels more krawly now than it did before.
Thunking too much makes me dizzy <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: "ROKIA" [Re: KIAFREEKROB] #645372 09/24/05 05:36 AM
MorganEstill Offline
The guy that gonna be doing the bedlining on my Sportage has a Mog with over 400:1 crawl ratio (!). Now THAT's insane.
'97 Sportage, 4" Lift 1" BL, 31" BAJA CLAWS, Rallye 4000s, Line-Xed Hood, Grille, K&N, 2.25" Exhaust, RS9000s, GPS...
"What is IFS and where can I get some??" (outerlimits4x4.com)
Re: "ROKIA" [Re: KIAFREEKROB] #645373 09/24/05 05:36 AM
The guy that's gonna be doing the bedlining on my Sportage has a Mog with over 400:1 crawl ratio (!). Now THAT's insane.
Re: "ROKIA" [Re: MorganEstill] #645374 09/24/05 04:17 PM
400:1 now that is awesome!
I have the axle brackets ordered from Blue Torch for the redesign of the rear shackle mounts. Should be here by Wed.
My optima crapped the bed internally, so the new one awaits install.
The destroyed rear himes are in hand & waiting for the new bracketry.
So the plans for shakedown #2 are still a go on the 1st of Oct @ Moonrocks.
Also finaaly found a battery isolator @ the motorhome store that needs to be installed & wired.
Will post more pics as I go.
Re: "ROKIA" [Re: KIAFREEKROB] #645375 09/25/05 06:42 PM
mattnsteph Offline
Rob tried calling ya the # I have didnt work changed phones and may have in-put it into the new phone incorrect. Give me a shout tonight around 9 or 10 if you get a chance.
Matt
In midst of building.
Re: "ROKIA" [Re: mattnsteph] #645376 09/25/05 07:11 PM
I sent ya a PM
Re: "ROKIA" [Re: KIAFREEKROB] #645377 09/25/05 08:49 PM
mattnsteph Offline
sent ya one back
Re: "ROKIA" [Re: mattnsteph] #645378 10/01/05 07:28 AM
Shakedown #2 set 4 2morrow @ Moonrocks. Will get some pics up after the weekend, Capmin & Partyin is after the wheelin.
Gotta columnist gunna do a shoot for 4wheel & Sport Utility Mag. Not real sure of the name of it?
Gotta trim the Fuel tank protector = the D-Line is hittin it.
Had to hammer the lower rear inner structure so it wouldent hit the tires.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6434 MB (Peak: 0.7511 MB) Data Comp: Off Server Time: 2026-06-23 00:45:47 UTC
