Page 8 of 9 1 2 3 4 5 6 7 8 9
Re: "ROKIA" [Re: KIAFREEKROB] #645399 10/10/05 03:47 PM
Dave Scott Offline
wow, mike, i am sorry, i didn't realize it was a problem, i will correct it. i will delete them in a few minutes. again, i am sorry, i didn't mean to cause any trouble.
Re: "ROKIA" [Re: Dave Scott] #645400 10/10/05 06:38 PM
DirtyHarry Offline
Toyota Moderator
Rob I am truly sorry that I did not get out to photograph your Rokia last weekend. I have been following your build over a year and cannot wait to see it in person. Fortunately we have plenty of places around Reno that are exactly what the Rokia was built for.
As Steve said earlier, I think that a 2WD transmission with a short jack shaft (basically two u-joints mated together) and an OTT divorce mount with a Toyota transfer case would be the way to go for lower gearing.
Work out the bugs you have now though before anything else Rob and that thing will go just about anywhere. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: "ROKIA" [Re: DirtyHarry] #645401 10/10/05 09:33 PM
MorganEstill Offline
Thanks Harry. I was thinking OTT made something like that... but could remember their website. I think that'd work perfect. Especially since there's SO freakin' much stuff avail. for Toy t-cases and whatnot.
You would happen to know offhand how long a toy t-case is would you?
How 'bout a dual t-case?
'97 Sportage, 4" Lift 1" BL, 31" BAJA CLAWS, Rallye 4000s, Line-Xed Hood, Grille, K&N, 2.25" Exhaust, RS9000s, GPS...
"What is IFS and where can I get some??" (outerlimits4x4.com)
Re: "ROKIA" [Re: MorganEstill] #645402 10/11/05 06:28 AM
DirtyHarry Offline
Toyota Moderator
Yeah there is a ton of stuff for Toyota transfer cases (gear sets, adapter plates, twin sticks, etc) and the prices are very reasonable.
Toyota transfer cases are just under a foot long (this is from memory so don't quote me) and dual cases add another 6.5" (adapter and low range box). Not sure how much extra length the OTT divorce mount adapter would need.
So who is going to be the first Kia to do this??? <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: "ROKIA" [Re: DirtyHarry] #645403 10/11/05 08:40 AM
DamKia Offline
Kia Moderator
That might be me...........single tfer (4.7: low), behind a 3.8 litre GM-Holden (Buick - Olds) V6 and 4L60E <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: "ROKIA" [Re: DirtyHarry] #645404 10/11/05 05:29 PM
I'm really liking the idea of a dual t-case setup with toy cases. I would've thought it the t-case would be 18"-20" or so - way longer. I certainly paln on eventually doing this, but only after or during the SAS which will probably be a year or two before that happens.
Re: "ROKIA" [Re: MorganEstill] #645405 10/11/05 05:48 PM
maraguez Offline
What about Suzuki Transfer cases. They hold up up to a small V8 engine and are lighter than the Yotas. I've seen many Toyotas and other 4x4 go with the Zuki transfer, they are highly respected by the Peterson 4wd mag and 4 wheeler.
1985 Toyota 4x4 4Runner. 1989 Suzuki Sidekick 4x4.
Re: "ROKIA" [Re: maraguez] #645406 10/11/05 06:36 PM
We've already discussd that issue. Zuk cases won't work because they have an offset rear d-line output.
Re: "ROKIA" [Re: MorganEstill] #645407 10/11/05 08:04 PM
maraguez Offline
Sorry for my ignorance, but, what's a d line output?
Re: "ROKIA" [Re: maraguez] #645408 10/11/05 09:01 PM
DirtyHarry Offline
Toyota Moderator
Instead of the rear axle being centered, it is offset to the passenger side just like the front axle. Toyota Land Cruisers, Land Rovers, and Suzuki Samurais are all like this. The transfer case has the rear ouput offset too, in line with the front output instead of being inline with the transmission. Using a Samurai transfer case would create packing constraints because of the gas tank, not to mention horrendous driveline vibrations at speed.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6490 MB (Peak: 0.7544 MB) Data Comp: Off Server Time: 2026-06-23 04:51:43 UTC
