Wiring nightmare #645422 09/09/05 01:30 PM
I bought a 94 Jeep wrangler. It was modified from a 2.5 to a 4.2L. The guy said he did not get the fuel, speedometer, or tach rewired. An MSD ignition box was installed. I started in yesterday trying to hook up these gauges. The original 2.5 L gauges are still there. The fuel gauge worked for a few minutes, then quit. I can't get the speedo or tach to work. Can anyone share simple thoughts on what I need to do? <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Wiring nightmare #645423 09/09/05 01:40 PM
bigjeep1980 Offline
This was a big help for me <img src="/forums/images/graemlins/cheers.gif" alt="" />
http://www.4x4wire.com/jeep/tech/electrical/gauges/
Re: Wiring nightmare [Re: bigjeep1980] #645424 09/09/05 06:53 PM
Thanks for the link which has contains some good information. However, can anyone tell me if I can use the stock gauges in my 94 wrangler since I changed the engine from 2.5L to 4.2L? That could be why the fuel, tach & speedo don't work when I hook them up?
Re: Wiring nightmare #645425 09/09/05 08:06 PM
BigJim Offline
I cannot think of a reason why not.. Surely the senders all send the same signals to the guages.
Re: Wiring nightmare #645426 09/09/05 11:29 PM
tomriddle Offline
where's the grounding strap? maybe it needs some new grounds installed here and there and under the dash.
94 yj 456gears, detroit locker and 30 spline axles out back, 33" bfgs
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.5978 MB (Peak: 0.6601 MB) Data Comp: Off Server Time: 2026-11-18 11:49:11 UTC
