Re: 3 Row Radiator Fitment Question [Re: coryc85] #646072 09/13/05 08:09 PM
87Toy4x4 Offline
i also have a 3 row radiator from radiatorbarn.com it fits great and cools great. my temp gauge always stays in the same spot.
Re: 3 Row Radiator Fitment Question [Re: coryc85] #646073 09/13/05 10:12 PM
TheBandit Offline
I used the 3.0 V6 radiator (3-row) for my '86 4Runner with 22RE. It mounted up to the stock 4cyl radiator location. I imagine it would be the same for your '83. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[color:"darkgreen"]1986 4Runner - 4" IFS - 63" Chevys - 33" ATs - 5.29s - Rear Detroit
Sliders - Kayline - Rebuilt 22RE - On Board Air AND Factory AC
www.xtremefabricator.com[/color]
Re: 3 Row Radiator Fitment Question [Re: TheBandit] #646074 09/13/05 10:49 PM
coryc85 Offline OP
Man you guys are coming out of the woodwork now. I left a msg for the rep for the TransPro/Go-Dan radiator, no response yet. I'll call radiator barn tomorrow and see if I can get theirs.
Thanks for all the responses. I knew I had heard good things about radiatorbarn. The one thing I do like about Roger's radiator is that the fan shroud nuts are already welded to it...it's the little things.
83 4x4, 3" Lift, 33" Buckshot Mudders
Re: 3 Row Radiator Fitment Question [Re: coryc85] #646075 09/14/05 03:43 AM
matts Offline
Autozone was carrying GoDan radiators earlier this summer. I am running a GoDan three row in my '84 xtra cab. Autozone lists it for the 4runner. In my case I just told them that I have a '84 4runner. This is the second one I bought from Autozone in 2 years, I damaged the first one. The second one was a bit rougher looking and I noticed that they were making them in China whereas before they were coming from the Philipines. I paid $180. Radiator Barn shows a three row, for the 1984 4runner with air conditioning, for $125. -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: 3 Row Radiator Fitment Question [Re: matts] #646076 09/15/05 12:42 AM
87Toy4x4 Offline
my three row was like 112 or something and it got to here in less than 2 days. great service.
Re: 3 Row Radiator Fitment Question [Re: 87Toy4x4] #646077 09/15/05 05:08 AM
Buck Offline
Guess I'll throw in my 2 cents as well. <img src="/forums/images/graemlins/smile.gif" alt="" /> Got my 3 row for my 84 extended cab from radiatorexpress.com. Took about 5 days to get here, ordered it on a Saturday online. Cost me $122, and the shroud nuts are already welded on! <img src="/forums/images/graemlins/kewl.gif" alt="" />
84 Ext. Cab Pickup.
Update 3 Row Radiator Fitment Question [Re: Buck] #646078 09/24/05 09:56 PM
coryc85 Offline OP
OK, so last week I ordered the TransPro 432041 3 Row radiator from Autozone for $135. It came in earlier this week and today I decided to install it.
First Problem: Radiator is too tall, it hits the frame crossmember which keeps the holes from lining up. I was afraid of this, which is one reason I wanted to buy a radiator locally so I could return it if needed. Turns out though, that it just barely hits the crossmember. I got out the angle grinder and removed about 1/8" to 3/16" of material from the edge of the crossmember. Then it easily slid into place and I bolted it down. Now, it also sticks up above the grill more than my OEM radiator, and I was afraid the hood wouldn't shut, but it shuts fine.
Second problem: Since this radiator is about 1" thicker than the old radiator, I couldn't slide the fan shroud between the fan blade and radiator. But, again I removed enough metal from the lower edge of the shroud until it would slip in between there.
Third problem: Not really a problem, just an FYI. My hoses were now just a little too long for the fatter radiator and they kindof looked kinked when they were attached. So I just trimmed a little off the end of both hoses, and now they look good.
I was a little disappointed to see this radiator made in China. But overall, I'm happy to find a 3 core that fits.
Re: Update 3 Row Radiator Fitment Question [Re: coryc85] #646079 09/24/05 10:06 PM
4Crawler Offline
I guess the '83s are a little different with the crossmember and what not. I have plenty of room to fit mine in the '85. On the '85, there is a removeable part of the fan shroud on the bottom that allows for easier installation, also the shroud is plastic. It is a tighter fit, for sure, but the additional cooling is nice.
Re: Update 3 Row Radiator Fitment Question [Re: 4Crawler] #646080 09/25/05 02:33 AM
coryc85 Offline OP
Yeah, apparently 83 (and earlier) has the crossmember sitting much closer to the engine than the later models. I really appreciate the tip on the TransPro radiator, so thanks Roger.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6351 MB (Peak: 0.7395 MB) Data Comp: Off Server Time: 2026-06-09 23:37:29 UTC
