Carburetor adjustment - power valve damaged? #647232 09/15/05 01:36 PM
MartinR Offline OP
In the process of trying to resurrect a neglected '87 Isuzu Trooper, I rebuilt the carburetor. However, I have had trouble adjusting it (RPM's don't stabilize, seems to still run rich even with mixture screw in all the way).
In the process of rebuilding I MAY have damaged the power valve, but I couldn't remove it to check, and wanted to get some feedback about it.
When I tried to remove the power valve, I just used a regular screwdriver WITHOUT notching the center (I later learned that a notched screwdriver apparently is required to keep from pressing down on the tiny rod in the center). I tried as hard as reasonably possible to remove the power valve, but I only succeeded in stripping the head (brass) and also applying a lot of pressure onto the tiny rod.
Would this pressure of the screwdriver on the rod of the power valve damage it sufficiently to allow an excessive amount of fuel to go through it?
If I have to replace the power valve, I assume that the only way to remove it is to drill it out, unless there is some other recommendation.
Thanks.
Martin
Re: Carburetor adjustment - power valve damaged? [Re: MartinR] #647233 09/16/05 01:42 AM
I think your on the right track with removing the valve. Maybe just drill out the center and use an easy-out.
I have an 87 P'up, and the carb was replaced with a new/remanufactered unit just before I bought it, I rebuilt it twice, cleaned it twice, adjusted the float numerous times, and still every now and again it runs like crap for a few days. Just like you describe. I think it has something to do with one of the electric solonoids on the carb. Or the common idea that the carbs are crap.
I had an 85 that was the same, untill I replaced the carb with a Weber I scored on Ebay.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.5858 MB (Peak: 0.6358 MB) Data Comp: Off Server Time: 2026-10-27 13:42:02 UTC
