Bearing Race Upside Down #647618 09/16/05 10:55 PM
Ok well I am working on my front end today and stupid me I tapped the race in upside down into the knuckle. How should I go about getting it out now? Can I heat the surrounding area up and see if I can get it to slide out or what?
Re: Bearing Race Upside Down #647619 09/17/05 02:38 AM
4
4mudder Offline
if you heat the surrounding area it will expand and not the bearing race. try to find a bearing puller from a local shop or something and get it out
89 K5 Blazer,TBI 350, 700R4, 6" lift, 40" groundhawgs,3/4 ton 14 bolt rear, 3/4 ton 10 bolt front, 4.88:1 Gears
Re: Bearing Race Upside Down [Re: 4mudder] #647620 09/17/05 02:40 AM
CraShYota Offline
could try putting it in the freezer for a few hours... though from what i remember about my races is they are a little tighter then that.. but cooling em off that much would help and it would be easyer to tap out.
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
Re: Bearing Race Upside Down [Re: CraShYota] #647621 09/17/05 11:05 AM
I cant take them out to put them in a freezer though lol. I think im gonna have to get a punch and basically destroy the race to get it out. How much can I expect to pay for a new race/bearing?
Re: Bearing Race Upside Down #647622 09/17/05 02:00 PM
CraShYota Offline
5-10 bucks
Re: Bearing Race Upside Down [Re: CraShYota] #647623 09/17/05 02:13 PM
smansfield Offline
this is how we do it where i work,if bearing is in wrong.
take a small paper cup,fill it with water put a small piece
of would in the middle and freeze it.heat outside of part that has the race in it,when hot,take cup off your
newly made cicle,run it around the inside of the race.
if the fit isn't to,to tight you may be able to get it out.
works on airplane engines.
1993 toy pickup xcab 4x4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6035 MB (Peak: 0.6681 MB) Data Comp: Off Server Time: 2026-06-18 08:06:16 UTC
