Page 1 of 3 1 2 3
I lifted my moms VX :) #648737 09/21/05 05:25 AM
onebadtrooper Offline OP
She's going to be so pissed when she finds out.................... <img src="/forums/images/graemlins/smile.gif" alt="" /> J/K.
Its nothing to major but I think it turned out really well.
I used OME 912's in the rear, no spacers. And got about 2 1/2" . Then cranked the front up to about an inch lower then the rear, to give it alittle rake <img src="/forums/images/graemlins/smile.gif" alt="" />. And it rides so much better too!!!
The vx springs were SO MUCH easier to get in and out than a rodeo!!!!! It only took about 20min to lift the rear total! <img src="/forums/images/graemlins/smile.gif" alt="" />. I did a ball joint flip in the front, but also no spacer. Anyway here's some pics...
The first pic is before the lift... [Linked Image] [Linked Image] [Linked Image]
This is just after the rear springs were installed.
Re: I lifted my moms VX :) [Re: onebadtrooper] #648738 09/21/05 05:43 AM
desertTrooper Offline
sweet! <img src="/forums/images/graemlins/kewl.gif" alt="" /> now how about slappin some bigger rubbers on that thing! are those the stock rims? they look purty <img src="/forums/images/graemlins/notooth.gif" alt="" />
1997 Trooper S 4x4 w/ MT
Re: I lifted my moms VX :) [Re: onebadtrooper] #648739 09/21/05 05:45 AM
E
EricsTJ Offline
very nice indeed! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
1997 Wrangler TJ 5 speed, 2.5 L. Mostly stock except for 31x10.50's on Black Rockcrawler Rims.
1998 Wrangler TJ 5speed, 4.0L. Rusty's 3.5 " lift,33"BFG,4.10 gears,Novak transfer case shifter
Re: I lifted my moms VX :) [Re: EricsTJ] #648740 09/21/05 05:49 AM
Thanks, and yeah there stock 18" rims. After these tires wear out I'll talk here into buying something good <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: I lifted my moms VX :) [Re: onebadtrooper] #648741 09/21/05 05:56 AM
Rodeo Guy Offline
Yep, looks good, but a little funny with the (relatively) low profile tires. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Mike
"Damn the carnage! Full throttle ahead!"
95.5 rodeo, 37" Trxus MT, dana 44/9", coil-overs, lockers..... http://www.cardomain.com/memberpage/550454
Re: I lifted my moms VX :) [Re: Rodeo Guy] #648742 09/21/05 06:00 AM
Yeah I know.....Thats why I'm going to try on my 35's <img src="/forums/images/graemlins/evil.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: I lifted my moms VX :) [Re: onebadtrooper] #648743 09/21/05 08:45 AM
holger Offline
just in case if she will NOT notice, I suggest some more visible for a lady mods: like, tube doors <img src="/forums/images/graemlins/smile.gif" alt="" /> she will definitely notice <img src="/forums/images/graemlins/smile.gif" alt="" />
Oleg
Deceased Rodeo'02 4WD.
Re: I lifted my moms VX :) [Re: holger] #648744 09/21/05 03:19 PM
F
Frisky Offline
I can drop my truck off if you are running out of mods on yours <img src="/forums/images/graemlins/lol.gif" alt="" /> You can put the rest of my lift on and "try" your tires on it. Then you can finish the bumper and make a winch mount for it. Man, the options are endless on my basically stock troop.
1992 Isuzu Rodeo 2WD (some assembly required). "If it doesn't fit....Force it!! If it breaks, it needed to be replaced anyway."
Re: I lifted my moms VX :) [Re: Frisky] #648745 09/21/05 05:41 PM
icu_runnin Offline
your mom has a nice ride. <img src="/forums/images/graemlins/kewl.gif" alt="" /> to bad all moms cant drive something with some flava to it <img src="/forums/images/graemlins/notooth.gif" alt="" />
92 Galant VR4 #501/1k - Turbo, All Wheel Drive with 4 wheel steering - Money eatin toy
89 Isuzu I-Mark RS sings to 7800 RPM - Daily Driver
Re: I lifted my moms VX :) [Re: onebadtrooper] #648746 09/21/05 06:43 PM
Triathlete Offline
You better be prepered to do a lot of cutting and pounding! I test fit a pair of 33s and without major front wheelwell surgery they will not fit (I have the same lift). <img src="/forums/images/graemlins/zombie.gif" alt="" />
The only way you will get 35s to fit is with a 3 inch body lift on top of the suspoension lift. But then the axle shaft will not be to happy for too long! SAS is the answer!
Billy
VEHICROSS.INFO
'99 Vehicross 3"OME lift Torsion bar crank Ball joint flip 31" BFG AT's (everyday)/MTR's (wheel'n) Trooper skids OBA...more to come!
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6451 MB (Peak: 0.7672 MB) Data Comp: Off Server Time: 2026-06-22 07:14:57 UTC
