94 Rodeo V6 - Heater Core Removal Question
#648886
09/21/05 08:27 PM
What a bad design, plastic hoses on the heater core...
**snap**
Does anyone know if the heater core on a 94 Rodeo V6 can be replaced without opening the A/C pressure lines or removing the A/C evaporator?
Thanks
'94 Rodeo V6 211,200 mi.
Re: 94 Rodeo V6 - Heater Core Removal Question
[Re: CIrrusnine]
#648887
09/21/05 08:55 PM
yes if it is anything like a 92 Pickup. you can unbolt the heater core box from the firewall and remove it. You might have to unbolt the condenser assembly and move it an inch to pull it out but the a/c lines run through a gasketed hole in the firewall so disconnecting the hoses should not be necessary.
CHRIS 98 Amigo, 92 Pup
PHP: 7.4.33 Page Time: 6.821s Queries: 15 (0.003s) Memory: 0.5881 MB (Peak: 0.6359 MB) Data Comp: Off Server Time: 2026-05-29 23:45:18 UTCValid HTML 5 and Valid CSS
