HELP, Dash Fire, updated Pics
#649226
09/22/05 09:44 PM
I'm driving along today and out of nowhere white smoke starts to fill the cabin. It's coming from the dash around the speedo and Tach. I pull over in a parking spot and start looking for the Fire Ext in the back and the smoke stops. I quicky disconnect the batttery. <img src="/forums/images/graemlins/angry.gif" alt="" />
What the hell is in there that could cause a fire? Everything was still working when I turned it off. The top was very hot so I sat there a while and waited for it to cool down. I didn't want to leave the truck and come back to a burned out hulk. No blown fuses? Could the speedo cable cause this?
Re: HELP, Dash Fire
[Re: LRJ4x4]
#649227
09/22/05 10:00 PM
Gauge cluster electronics maybe? I doubt the speedo cable or you'd hear it.
Re: HELP, Dash Fire
[Re: LRJ4x4]
#649228
09/22/05 10:11 PM
I have no idea, but please be sure to post your findings on this one. What could happen to one '88 could happen to another. <img src="/forums/images/graemlins/scared.gif" alt="" />
Good luck Les...I hope it's quick, easy, and inexpensive to find/fix. <img src="/forums/images/graemlins/patriot.gif" alt="" />
?_________ |_|_|\____\___ l-----[O]≡≡≡≡[O] ()_)()_)-----)_) Stay the Trail!
Re: HELP, Dash Fire
[Re: LRJ4x4]
#649229
09/22/05 10:21 PM
I have a spare 87 wiring harness for a manual tranny and a few other parts from the smoking area.
Re: HELP, Dash Fire
[Re: Kevin C]
#649230
09/22/05 10:34 PM
Thanks, I'll try to get it pulled tonight. I'm curious as to the damage. I'll take the digital cam so all can see <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: HELP, Dash Fire
[Re: LRJ4x4]
#649231
09/22/05 10:43 PM
Blower resistor, blower motor, blower switch, all high currant draws to create a fire.
Re: HELP, Dash Fire
[Re: wyleone]
#649232
09/22/05 11:02 PM
Check the gate lock switch. Mine self-destructed recently through my own stupidity, and there was certainly white smoke coming from the dash... <img src="/forums/images/graemlins/frown.gif" alt="" />
Eric
Re: HELP, Dash Fire
[Re: 89IsMine]
#649233
09/23/05 12:09 AM
Got a critter munching on the wires? Rats love insullation on wires.
Re: HELP, Dash Fire
[Re: LRJ4x4]
#649234
09/23/05 12:42 AM
In the absence of physical evidence, an area of possibility is the fuel gauge since it incorperates a constant voltage relay which reduces battery voltage to 7 volts for this guage and the water temperature guage. If this is a mechanical relay and the points fuse together, the coil might short and burn. If the relay is a solid state type and shorts, it typically smokes. Resistane values for the guage are given on page 8-124 of the 87 FSM. Hope the damage is minimal.
1987 Raider 2.6L 5 spd w/ LSD off road package 130K miles 1987 Conquest 2.6L 5 spd w/ intercooler 56K miles 2000 4Runner locking RA 34k miles
Re: HELP, Dash Fire
[Re: philCA]
#649235
09/23/05 01:04 AM
Good point.. Another place to look is the switch for the emergancy flashers, less likely to smoke but still trouble prone.
Kevin
