Page 3 of 4 1 2 3 4
Re: HELP, Dash Fire [Re: fasteddy] #649246 09/23/05 10:31 PM
LRJ4x4 Offline OP
Took it apart.....NOTHING. I gave everything a real good look with a flashlight down in there. I couldn't find anything. I know it was smoke inside there because that's where it came from and the top was hot. I reconnected the battery today and everything is fine. It's very strange.
Take a look
My baby girl.
Re: HELP, Dash Fire [Re: wyleone] #649247 09/23/05 11:38 PM
8
89IsMine Offline
Because the Blower resistor gets very hot under normal operation, once the load resistor coils get old (or trash gets on them) the resistance shoots up and will burn the plastic ect around it. They are bolted into the air ducting so the airflow from the blower will cool it. Thus the smoke ect will be distributed through the vents.
OK, now I see the thought process. Thanks for clarifying that!
Eric
Re: HELP, Dash Fire [Re: LRJ4x4] #649248 09/24/05 02:57 AM
Those gauge pictures look rather amazing. No where near as much as that last pic, though... <img src="/forums/images/graemlins/baby.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: HELP, Dash Fire [Re: MontyMcV] #649249 09/24/05 03:52 AM
Jamez Offline
The dreaded door buzzer! I had one of those for a couple door openings.
'87 Raider w/rebuilt 2.6
Weber 32/36
Re: HELP, Dash Fire [Re: LRJ4x4] #649250 09/24/05 04:19 AM
W
wyleone Offline
I guess the next thing to do is test operate all controls. Try to remember everything that was on. Mitsu uses alot of ground switched circuits, so a low amp short to ground can be hidden easily. There are also alot of relays for wiper timing and hazard and signal flashers in the left kick panel and behind the fuse block.
BTW Les, Is there no dirt in that Montero at all?? even the anti rattle foam on the main cluster connector looks new. <img src="/forums/images/graemlins/wink.gif" alt="" />
She's getting big!!! It's amazing how fast they grow. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: HELP, Dash Fire [Re: wyleone] #649251 09/24/05 06:17 AM
LRJ4x4 Offline OP
The dash is cherry because of this, the only one I've ever seen.
That's Death Valley Dust in the vents, it's baby poweder fine.
Thanks for the help i'm going to look at it again and report back.
Re: HELP, Dash Fire [Re: LRJ4x4] #649252 09/24/05 09:47 PM
DougH Offline
Mitsubishi Forum Moderator
Did that cover come from John Baker?
DougH
1995 SR - RIP
1993 RS - RIP
Re: HELP, Dash Fire [Re: DougH] #649253 09/24/05 09:51 PM
52degrees Offline
Did John Baker go around to the wrecking yards and put dash mats on monteros? <img src="/forums/images/graemlins/lol.gif" alt="" />
Clay
KG6VNX
Re: HELP, Dash Fire [Re: DougH] #649254 09/25/05 12:42 AM
LRJ4x4 Offline OP
Dash mat was a junk yard find, Paso Robles, CA IIRC
<img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: HELP, Dash Fire [Re: LRJ4x4] #649255 09/25/05 01:01 AM
W
wyleone Offline
It smelled electrical for sure, Les? Just curious, The heater core can leak and cause a steamy mist too. I'm just reaching for any possibility. Not likly though. <img src="/forums/images/graemlins/smile.gif" alt="" />
Any new info?
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6425 MB (Peak: 0.7509 MB) Data Comp: Off Server Time: 2026-06-21 17:50:29 UTC
