Tranny filter Q's
#650644
09/28/05 12:31 AM
I dropped the stupid cross member, dropped evey bolt in the hot trans fluid and cut most of my knuckles, BUT the filter is out! My question is when I pulled the filter 2 more quarts of fluid came out. I am hoping that means the filter was clogged ??? Also I need to drain the Torque converter is there a drain on them I can bump around and unscrew?? Need to get all the contaminated fluid out of system. Should I drop the valve body or do little springs and balls go shooting every where?? Why is there a cross member over the pan ?? Man thats insane to change the filter. Ok I'm done, I will await an answer on my 2600 baud C-64. Thanks.
Re: Tranny filter Q's
[Re: FranklinP]
#650645
09/28/05 03:59 AM
The filter is not really a filter but a screen. It is not meant to be changed regularly.
When you drop the screen, it is normal for more fluid to come out. Does not mean that it was clogged.
The torque convertor does not have a drain plug. To drain the tc you need to remove it or run your tranny thru a fluid exchange machine. There are people who have done a fluid exchange themselves by running the vehicle & removing hoses to force fluid out. It's risky & is best left to a pro.
Not sure about dropping the valve body. There are usually springs & ball bearings in valve bodies.
None
[Re: FranklinP]
#650646
09/28/05 04:30 AM
If you drop the valve body, you may damage the valve body gaskets and there are three accumulators that can fall out with their springs, you do not want to mix up the springs or the pistons. If you have an FSM it will help if you decide to drop it. You will only drain 1/2 the convertor if you drop the valve body. If the fluid is that contaminated, you may want to try a power flush. If not, multiple trans services will clear it up slowly.
[Re: wyleone]
#650647
10/03/06 03:00 PM
I'll be doing this job shortly. The only way I can see to do this properly is to drop the pan and clean the screen, replace the lost fluid, take the truck to a shop and get the trans flushed. I'm guessing I'll need to take diamond ATF from Mistu with me as I doubt shops stock the right fluid.
On the other hand, with just over 100K miles on my truck should I expect the screen to be dirty/clogged? If not be may a flush in sufficient?
What's the general feeling on this?
[Re: Mad_Scientist]
#650648
10/03/06 03:07 PM
More thoughts...I know there are flush machines that hook up to the pump inlet with the pan dropped. Dropping the pan is good, as you all know, since is gives you the chance to assess the condition of your tranny and you can clean out any crud sitting in there. I just don't want someone else doing that kind of work on my truck and I especially don't want to pay someone to do something I can do myself.
[Re: Mad_Scientist]
#650649
10/03/06 03:44 PM
I have flushed the fluid on my '03 by disconnecting the trans cooler tube. It is actually the method recommended in the FSM. I did not find it difficult and it was nice to know that I changed out almost all of the fluid. Most of the newer flush machines hook up to the cooler lines to make the process more convenient. However, it can easily be done by most shade tree mech's. Here is what I did.
1. Drive the car for about 20 min to get everything nice and warm. 2. Drain the fluid from the pan using the drain plug. 3. Replace the fluid that was drained. About 4 qts. 4. Disconnect the tube that connects to the lower end of the tranny cooler (on an '03 it is a little 4" long "U" tube) 5. Connect a piece of clear tubing and direct the flow into an bucket. 6. Run the truck for about 15-20 seconds. You will get about 2qts out. Then top up the tranny. 7. Repeat until you have gone through about 9-12 qts. 8. If you have a helper they can watch the fluid come out of the tube and when they start to see bubbles, you turn of the truck.
This method is described in my '03 FSM and I have seen it on many other forums.
I only used 10 qts. When I was done I did a blotter comparison between the old fluid, the new fluid from the bottle and the fluid in the tranny after flushing. While it did not match the pristine fluid from the bottle, it was very close. The old fluid in the tranny was very brown after only 30k.
'90 Montero XLS (Sold, sadly) '95 Montero LS 160k '03 Montero Limited 30k
[Re: Winston]
#650650
10/03/06 03:49 PM
Yeah, I think that's a great way to do it. The reason I say that is b/c I was just reading this thread; http://www.cadillacforums.com/forums/ht4100-4-1-4-5-4/10160-should-i-flush-tranny-52k.htmlI it found using google and I know it's a different vehicle but it puts me off the idea of ever getting a shop to 'machine flush'. I'm going to flush the you did Winston <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Mad_Scientist]
#650651
10/03/06 09:38 PM
I would be scared away from flushes by reading that post on the Cadillac forum, except that I have personally used one. Unless the machines have changed drastically in the last 4 years, I think there is some misunderstanding about how a flush machine works. The machines at the dealership that I worked at would be connected to the transmission cooler supply & return hoses, and the vehicle would be started. The transmission would pump out the old fluid into the flush machine, and the flush machine would pump an equal amount of new fluid from a 30 gallon drum back into the transmission. There was no intermingling of old & new fluids, other than inside the transmission, so there was no danger of getting someone else's bad fluid pumped into your tranny. It's much better than just draining & refilling your fluid one time, but if you have the time, multiple drain & refills will accomplish roughly the same result.
95 Montero SR 3.8 MIVEC, Advance headers, 2 1/2" exhaust, Magnaflow muffler, OME shocks & rear springs, 2" body lift, 3" tank lift, 4.90s, TRE front locker, factory rear locker, Roger Brown Rock Sliderz, 315/75r16 (35") tires, Sport big brakes
