Re: Need suggestions. 95 SR. Not being very friendly. [Re: ATCGuy] #652020 10/04/05 04:03 AM
Just to be sure... was the vehicle out of gear when checking the crankshaft? I've made that mistake when I did mine. Won't turn if in gear.
Re: Need suggestions. 95 SR. Not being very friendly. [Re: off-roader] #652021 10/04/05 04:34 AM
bOURGE Offline
dude i feel your pain...(rebuild gone terribly wrong). please tell me that this was just a toy and not your only source of travel? sorry man.
bourge
1995 Montero SR
1999 Montero
1974 Ford Bronco
Re: Need suggestions. 95 SR. Not being very friendly. [Re: bOURGE] #652022 10/04/05 05:03 PM
W
Winston Offline
Can you tell us a few more details? If you say the cams turn but the crank doesn't. Does that mean that you took the timing belt off again? Please fill us in.
It moved around like a washing-machine that is out of balance, but did not fire.
I just saw that note from your post. That is a really bad sign.
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
Re: Need suggestions. 95 SR. Not being very friendly. [Re: Winston] #652023 10/04/05 06:26 PM
A
ATCGuy Offline OP
Yes. We took the timing belt back off. The crankshaft will not budge. I believe my friend even took the intake back off, and the plugs out. Now, I'm in search of an engine I guess. <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Need suggestions. 95 SR. Not being very friendly. [Re: ATCGuy] #652024 10/04/05 06:57 PM
You're supposed to try and rotate the engine over with the belt STILL WRAPPED and installed on the engine. If your rotating the crankshaft only with the Tbelt off, surely your going to run into an open intake/exhaust valve which will stop the rotation. No offense meant but my 1st suggestion is to get another mechanic friend.
Joel, CA
Re: Need suggestions. 95 SR. Not being very friendly. #652025 10/04/05 07:30 PM
W
Winston Offline
I think Joel hit the nail on the head. Fire your friend and tow your car to a real mechanic. Hopefully the dealer. It will be worth an hour of their time to tell you if anything is salvagable.
'95 Montero LS 160k
Re: Need suggestions. 95 SR. Not being very friendly. #652026 10/11/05 04:13 PM
scaesare Offline
Joel, CA
Unfortunately, the FSM has an error in this regard. <img src="/forums/images/graemlins/confused.gif" alt="" />
I dunno if that same error has made it into the 3rd party service manuals.
-Steve
-1995 Montero SR 3.5L V6 DOHC
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6218 MB (Peak: 0.7000 MB) Data Comp: Off Server Time: 2026-06-07 02:17:30 UTC
