Quick pinion preload question #652274 10/03/05 04:46 PM
carter Offline OP
Quick question. When setting the pinion preload, do you measure the torque needed to get it to start rotating, or the torque while rotating?
This is using a solid spacer with used bearings. It takes about 25 in-lb to get it to begin rotating, and about 6 in-lb to maintain rotation. Bearings are oiled.
Thanks!
Mike Carter
85 & 86 4Runners
My Website
Re: Quick pinion preload question [Re: carter] #652275 10/03/05 11:31 PM
ZUK Offline
6 in/lb is the correct number. <img src="/forums/images/graemlins/kewl.gif" alt="" />
mostly stock
Re: Quick pinion preload question [Re: ZUK] #652276 10/04/05 12:35 AM
carter Offline OP
So it is ok for it to take a lot more torque to begin rotating? It didn't feel like that when I disassembled it. I didn't take any torque readings on disassembly.
Mike Carter
85 & 86 4Runners
My Website
Re: Quick pinion preload question [Re: carter] #652277 10/04/05 04:03 AM
ZUK Offline
ya...that can happen. use a thick gear oil....like a teaspoon on both bearings. Helps to smooth it out.
mostly stock
Re: Quick pinion preload question [Re: ZUK] #652278 10/04/05 10:16 AM
carter Offline OP
Cool, thanks! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Mike Carter
85 & 86 4Runners
My Website
Re: Quick pinion preload question [Re: carter] #652279 10/05/05 11:03 AM
carter Offline OP
Yep, that fixed it.
Mike Carter
85 & 86 4Runners
My Website
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6060 MB (Peak: 0.6754 MB) Data Comp: Off Server Time: 2026-06-07 14:28:13 UTC
