Page 9 of 11 1 2 7 8 9 10 11
Re: WTF, Extra parts and it won't start.. [Re: conner] #653354 11/18/05 02:11 PM
johnpsz Offline OP
Thanks for all the help guys...
I will try this test tomorrow, it sounds simple enough anyway...
I will let you know the results, thanks again...
John Pszenyczniak
67 Mustang Coupe
95 Firebird Formula
05 Ram hemi 4x4
91 Montero RS LWB w/ 320k miles before rebuild, 900 down and its still kicking!!!
Re: WTF, Extra parts and it won't start.. [Re: johnpsz] #653355 11/18/05 06:01 PM
W
Winston Offline
Is it possible to dissassemble the TPS and clean it with electrical parts cleaner?
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
Re: WTF, Extra parts and it won't start.. [Re: Winston] #653356 11/18/05 09:51 PM
conner Offline
Not really Winston: Typically the wiper part of the poteniometer wears out or the resistor goes south. The only time i was able to accomplish that, was when someone steam cleaned their engine and forced water in.
Conner
Over the hill but still climbing.
88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
Re: WTF, Extra parts and it won't start.. [Re: conner] #653357 11/20/05 08:59 PM
johnpsz Offline OP
My results are in red below.
Here is how i would test the TPS. Disconnect the connector at the TPS and measure voltage on the harness side with key on.
Y/R wire-------12 volts [color:"red"] 4.67 [/color]
G/B wire-------Ground [color:"red"] Good [/color]
G/Y wire-------5 volts [color:"red"] Good [/color]
Plug connector back on and read voltages
Y/R wire-------Throttle closed----0 volts
Throttle opened----12 volts
G/W wire-------Throttle closed----.05 to .08 volts
Voltage should increase smoothly as throttle is opened to full position.
If the first set of tests are good and one of the second set of tests fail, the TPS is bad.
Conner
I also checked the voltage to the TPS Y/R wire at the ECU and it still read 4.67, rulling out a bad wire not getting the voltage to the TPS. I also didn't do any of the other tests because I thought they were dependant on the first set of tests. So does this make it a bad ECU?
John Pszenyczniak
67 Mustang Coupe
95 Firebird Formula
05 Ram hemi 4x4
Re: WTF, Extra parts and it won't start.. [Re: johnpsz] #653358 11/20/05 09:54 PM
FrankR Offline
If I understand the test method Conner gave you, it does sound like the ECU is not providing the correct voltage to the TPS. Have you tried cleaning/tightening the ECU connection to body/chassis ground?
Frank
Re: WTF, Extra parts and it won't start.. [Re: FrankR] #653359 11/20/05 11:32 PM
johnpsz Offline OP
The ECU (or at least that one wire that grounds to that ECU mounting screw) was grounded when testing it under the hood, but when I dropped the ECU to test it there I didn't remount that wire and got the same reading.
Or, is there another ground I am missing?
John Pszenyczniak
67 Mustang Coupe
95 Firebird Formula
05 Ram hemi 4x4
Re: WTF, Extra parts and it won't start.. [Re: johnpsz] #653360 11/21/05 04:05 AM
FrankR Offline
I have not checked to see how it's grounded, but I suspect there's a black wire coming out of the ECU connector harness that goes to body ground - maybe one from each connector harness.
Frank
Re: WTF, Extra parts and it won't start.. [Re: johnpsz] #653361 11/21/05 01:31 PM
conner Offline
John: That portion of the test is for the idle switch. This tells the ECU whether the throttle is opened or closed. What is confusing here, is that the wiring schematic shows 12 volts going to the switch while the testing procedure in the FSM shows 4 volts or higher as ok. finish with the complete tests and let me know results.
Thanks
Conner
Re: WTF, Extra parts and it won't start.. [Re: johnpsz] #653362 12/04/05 09:57 PM
johnpsz Offline OP
Conner,
I finally had a chance to get back to checking this thing out and I am still a little baffled...
Y/R wire-------Throttle closed----0 volts [color:"red"] Good [/color]
Throttle opened----12 volts [color:"red"] 4.67 [/color]
G/W wire-------Throttle closed----.05 to .08 volts [color:"red"] .687[/color]
Voltage should increase smoothly as throttle is opened to full position. [color:"red"]Good[/color]
Conner
You mentioned in the post above that the FSM shows anything over 4 volts is good on the Y/R wire.
So I am unsure if the test failed, the numbers for the Y/R wire test matched the top proving the switch opens without much resistance, but the numbers definitly were not in range on the last test of the G/W wire they started at .687, no mater what movement of the TPS (clocking it), and ramped up to around 4.9x volts, the ramp is smooth but not sure it the numbers being off are that bad???
Also when clocking it it is a pain in the <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> to get it calibrated, the thing jumps around like crazy... Are these signs of a dead TPS?
John Pszenyczniak
67 Mustang Coupe
95 Firebird Formula
05 Ram hemi 4x4
Re: WTF, Extra parts and it won't start.. [Re: johnpsz] #653363 12/06/05 02:57 PM
conner Offline
John: If it is jumping that bad, i would replace the TPS. What was your original problem? Or i should ask what is it doing now? There is too much to comb through on this post.
Good luck
Conner
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6538 MB (Peak: 0.7594 MB) Data Comp: Off Server Time: 2026-06-17 11:51:58 UTC
