Re: Oil temperature [Re: fasteddy] #654646 10/18/05 10:41 PM
DanWheeler Offline
oh yeah, the starion oil cooler goes in really easy. i dont think it does a d*mn thing for me though. pics for installation here:
http://danwheeler.gotdns.com/pics/Auto/Montero/StarionOilCooler/
1986 Montero 2.6l
31X10.5 BFG MT - Weber carb with custom intake
Rear LSD - RCI seats - Oil cooler - Manual hubs
Custom bumpers front and rear + rock sliders
Re: Oil temperature [Re: DanWheeler] #654647 10/18/05 11:22 PM
Kevin C Offline
Nice pics, like the ARP head studs. Do you still have the ôpotö type converter? The 87 and later exhaust manifold should give you a little more pulling power.
Kevin
Re: Oil temperature [Re: Kevin C] #654648 10/18/05 11:25 PM
DanWheeler Offline
i'm not sure.. i assume by converter your talking about the cat?
what do you mean by pot type?
1986 Montero 2.6l
Re: Oil temperature [Re: fasteddy] #654649 10/20/05 05:59 PM
TobyB Offline OP
all the gen1 Monty V6 engines I've dealt with either have the cooler attached to the oil filter boss, or have it plugged there, with no thermostat installed. If there's a different housing with no fittings, it would be pretty easy to swap the whole housing for one that has them. Assuming, of course, that the oil pump is the same! <img src="/forums/images/graemlins/notooth.gif" alt="" />
t
'89 V6 4dr- '4- Doris'
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6089 MB (Peak: 0.6649 MB) Data Comp: Off Server Time: 2026-06-10 06:11:52 UTC
