Page 3 of 3 1 2 3
Re: BJ Flip on 1998 Rodeo? EDIT: additional confusion... [Re: NATO308] #654698 11/05/05 02:03 AM
Don_W Offline
What do you mean by "flipped the ball joints"?
Don
1989 Trooper II 2.6L
222,222
Re: BJ Flip on 1998 Rodeo? EDIT: additional confusion... [Re: Don_W] #654699 03/20/06 02:38 AM
I have been reading about ball joint flips on "Expedition West" and it stated that doing the flip will help with additional travel after a Torsion Bar lift and it will also help with alignment. The concern seems to be that this will encourage Rack damage. My question is could I just beef up the droop snubbers and then do the ball joint flip on the UCA so that I can get better alignment?
Thanks!
Re: BJ Flip on 1998 Rodeo? EDIT: additional confusion... [Re: Don_W] #654700 03/20/06 03:08 AM
CPOM Offline
Meaning move the upper balljoint from its mounting spot above the upeer a-arm to below the upper a-arm. It helps with correcting lifted wheel camber (alignment).
CHRIS
98 Amigo, 92 Pup
Re: BJ Flip on 1998 Rodeo? EDIT: additional confusion... #654701 03/20/06 03:10 AM
CPOM Offline
Thanks!
You don't get any more travel, ok maybe an insignificant amount. I would try to get it aligned first and see if they can get camber specs to normal versus try this just incase because some people have damaged thier rack+p steering from this. If it is still way off then explore options.
CHRIS
98 Amigo, 92 Pup
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6018 MB (Peak: 0.6762 MB) Data Comp: Off Server Time: 2026-06-14 00:52:16 UTC
