Window Motor Removal #655332 10/11/05 07:43 PM
MeatWagon Offline OP
-tried searching for this but couldn't find what I'm lookin' for...
My 91 Trooper's rear driver side power window has stopped working. I pulled the panel off, found the 2 blue wires that go the motor & verified that I get + or - 12vdc when I use a window switch, so I figure the problem has to be with the motor.
I read in some posts that windows sometimes bind..but this is stuck (thankfully) in the full-up position & won't move.
Anyhow...has anybody removed/replaced one of these motors? I'm not sure if I need to get inside the door, or if it all can be done through the access hole. My svc. manual says nothing about them (of course).
'90 Trooper LS 2.8, 5spd, 3" body lift, 33x12.5, dent
Re: Window Motor Removal [Re: MeatWagon] #655333 10/11/05 11:49 PM
Jim_Paget Offline
I have replaced them in the front doors on a '91 but not the back, but the procedure is pretty much the same. You need to remove the door panel and then everything can be removed through the access holes.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5868 MB (Peak: 0.6352 MB) Data Comp: Off Server Time: 2026-06-21 00:36:07 UTC
