Try this. Smell it. Hot, cold, running, off, it should not matter. If it smells like fuel or exhaust, then there might be a problem.
Take a nasty shoprag and light it on fire let it burn for a second,then put it out.If your radiator fluid smells like that nasty burnt rag then you might verywell have a blown head gasket/cracked head..........momma ain't been hotroding her Trooper has she <img src="/forums/images/graemlins/notooth.gif" alt="" />.
Anyways do a compression test and leak down test.Not sure of the numbers but try it for cylinder to cylinder comparison.
Compression test
remove fuel pump fuse( and run engine out of gas)
Remove all plugs
prop open throttle plate
screw gage into plughole
turn engine over at least 2 full turns and record highest reading.
repeat----this will tell you the Lbs of pressure per cylinder they should be w/i 10%
If you have a low cylinder put about a teaspoon of oil into the cylinder ( a syrenge works best covers all parts of rings)
retest that side
if numbers improve than rings are leaking
if not then either valves are leaking or major head problems
Which brings up a leakdown test
very similar to compression test but you need a leakdown tester.
Remove fuse and run engine dry
remove plugs
ensure valves are closed for each cylinder being checked
insert tester gage
apply 90lbs or so of pressure
remove air source
see how long air takes to leak out
in a perfect world none will leak out.
record all cylinders if 1 is low then repeat oil step as above to see if this "seals" the rings,if one cylinder is alot different than the others there is something wrong in the head area.
This will also allow bubbles to escape thru the coolant.
If the thermostate is closed bubbles will not appear so take out the thermostate before applying air to the engine.
This air into the cylinders will actually hold a valve closed to repair valve seals/springs........only keep the air applied so the valve doesn't drop down.
Disclaimer---check pressure req. and readings in the service manual before doing this <img src="/forums/images/graemlins/smile.gif" alt="" />
Goodluck
