Page 3 of 5 1 2 3 4 5
Re: more cooling problems..... '89 Trooper 2.6L #657836 10/20/05 01:53 PM
RobG Offline OP
I appriciate all the help guys, this is great stuff. I'm gonna go home tonight and do a quick cylinder pressure test and examine more closely for bubbles. If that turns up nothing, I'll see about finding a leakdown guage.
If your radiator fluid smells like that nasty burnt rag then you might verywell have a blown head gasket/cracked head..........
there is no decernable smell. the fluid itself appears (and smells) normal.
It's normal for coolant to enter the expansion tank whilst engine reaches normal op temp, and to be slurped back in as it cools.
Well, the problem is, what is puked out into the overflow never gets sucked back in. leaving the radiator significantly empty.
Half the rad's contents sounds extreme, how much did you actually add?
dumped the entire contents of the overflow back into the radiator plus about a liter of additional water.
-Rob
Re: more cooling problems..... '89 Trooper 2.6L #657837 10/20/05 02:15 PM
ShowMeDave Offline
....... Should have a lab assistant in a wetsuit and goggles for that test.........
Good plan! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
David
?'90 Trooper?2.6L?Auto?DELTA Cam?AMC Head?"DN" Lift?SlakAzz Sliderzz
?TrXus M/T's?Black Rockcrawlers?Lockers by MIG & ARB?ProComp ES9000's
?Pics and junk...Thx Tad!!
Re: more cooling problems..... '89 Trooper 2.6L [Re: RobG] #657838 10/20/05 02:23 PM
jezeric Offline
Isuzu Moderator
Just throwing out oddball ideas, since most of the good ones are taken <img src="/forums/images/graemlins/pfft.gif" alt="" />, but are you sure there isn't some sort of blockage in the overflow tubing that isn't allowing the coolant to be drawn back into the radiator? if there's a bit of junk in the line that's blocking the return it might just be the normal action of your coolant's expansion over several runs isn't able to reverse. The draw back into the radiator isn't that strong, a little bit of junk between the cap and the tank may be enough to gum up the works.
James
Re: more cooling problems..... '89 Trooper 2.6L [Re: jezeric] #657839 10/20/05 02:32 PM
Jim_Paget Offline
That's why the unnamed person above had the problem he did - there is a check valve in one side.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: more cooling problems..... '89 Trooper 2.6L [Re: Jim_Paget] #657840 10/21/05 02:08 AM
RobG Offline OP
well, just finished a round of diagnostics tonight and here's what more I can add....
a simple pressure test didn't reveal much beyond normal. cylinders 2,3,4 are all very close to each other at ~155psi. cylinder 1 is a little behind at only ~142psi. but all is considered within range by my Haynes manual.
One thing I did notice was the plugs on #3 and #4 contained a fair amount of ash for only being a few months old. could this be a possible indication of coolant entering the combustion chamber and getting burned off?
Furthurmore, I uncapped the radiator and attempted to watch for bubbles as the engine was turned over. I think I did witness a few blurps, but unsure if this was trapped air or not. A significant amount of coolant was pushed out the top during this process. Also noticed, after i recapped the radiator and proceeded with the pressure testing, the system build up a large amount of pressure just from being turned over again and again (not running). not sure if this sort of pressure buildup while not running is normal.
I guess i need to do a percent leakdown test to definitively determine if the head gasket is intact or not.
-Rob
Re: more cooling problems..... '89 Trooper 2.6L [Re: RobG] #657841 10/21/05 03:37 AM
Sadly, no, it is not normal. Compression seems to be leaking past the head gasket or thru a crack in the head itself. One thing I'd like you to please try before pulling the head. Would you pull torque first? Particularly notice loosness on left front and left rear (driver's side) bolts where the locating sleeves are for the gasket/head. Seems there is not much relief in the recesses sometimes.
Re: more cooling problems..... '89 Trooper 2.6L [Re: RobG] #657842 10/21/05 03:38 AM
mlclark Offline
Isuzu Moderator
Rob,
I am not sure how you got it to build pressure into the coolant by just turning it over for the test. You did have all the plugs pulled, right?
I would more suspect the radiator. I would guess that the WP is pushing coolant into the radiator but it is not flowing through it. So, it either comes out of the neck (if the cap is off) or into the overflow tank. If the rest of the system is functional, it may be flowing enough to cool the engine but the flow through the radiator is clogged enough to push coolant out, too.
Good Luck,
Michael
Re: more cooling problems..... '89 Trooper 2.6L [Re: RobG] #657843 10/21/05 03:42 AM
FSJ1978 Offline
I'm not really a gambling person by nature, but I'd BET that if you put air pressure in those cyliners, you'll find that you'll push air out into the radiator. Our Amigo had the same problem, and ran for quite awhile. It finally went bad a couple months ago though and is now undrivable running on 3 cylinders.
Chris Enos (Chino, CA)
'91 Isuzu Amigo "Rover" (Camaro 3800 swap in progress / 2.25" exhaust)
....(SOA / Custom rear bumper / CB / HAM)
Re: more cooling problems..... '89 Trooper 2.6L [Re: mlclark] #657844 10/21/05 01:08 PM
RobG Offline OP
No, I pulled and tested one by one. is that a mistake, should I have had all the plugs removed at the same time?
-Rob
Re: more cooling problems..... '89 Trooper 2.6L [Re: RobG] #657845 10/21/05 07:54 PM
mlclark Offline
Isuzu Moderator
Yes, you don't want the engine working against itself on those other 3 cylinders while you are cranking. You should have the throttle wide open too. (Pull the fuel pump relay and fuse).
Michael
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6461 MB (Peak: 0.7571 MB) Data Comp: Off Server Time: 2026-05-29 14:37:53 UTC
