Amigo fenders on a Rodeo?
#658758
10/22/05 07:26 PM
Anyone ever compare the fenders from an Amigo to a Rodeo? I'm running a 96' Second Gen and I've always noticed that the fenders look like they're flared wider on an Amigo of similar build. I'm curious if this is an illusion or if anyone has looked into using them on a Rodeo. This would be great for tire clearance if they can be bolted up or coaxed into place. Anyway, just a thought to see if anyone has look at measurements on the fenders or knows where I could get dimensions on them. Thanks again guys and gals!
Re: Amigo fenders on a Rodeo?
[Re: Xanatos]
#658759
10/22/05 07:52 PM
First Gen Amigos / First Gen Rodeosà Yep, the fenders bolt right on, from one to the otherà and no, itÆs not your imagination - the Amigo fenders are wider.
(But since when is a 1996 Rodeo a Second Gen ???????)
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
[Re: Smiley]
#658760
10/22/05 08:06 PM
Oops, guess I hit the crack rock too early this morning. J/K. Don't know where my head's at. Guess I was just thinking about an engine/tranny swap I'm planning from a second gen to a first gen. Thanks.
3.2L V6 SOHC 1996 Isuzu Rodeo. Flowmaster exhaust / K&N High Flow Intake / Kenwood headunit / Audiobahn Subs / Alphasonik/Kenwood/Sony Amps / 180 amp High-output alternator / Redtop Optima battery / Custom hood w/ scoop
[Re: Xanatos]
#658761
10/23/05 02:31 AM
I had amigo fenders on my rodeo they bolt right on and fit perfect the front end looks alot more agressive too
94 Rodeo 3+3 lift Red) 95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2 front winch bumper custom rear bumper, Hella 500's 2004 Silverado duramax
[Re: Xanatos]
#658762
10/23/05 08:59 PM
I've picked up the right fender for my pickup, still looking for the left side. The wider fenders will give the truck an aggressive prerunner look.
Make sure you get the inner fender from the Amigo as well.
<img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> '92 Pickup - 2" BL, 1.5" SL, 4.3 TB swap, 2.25" exhaust, Amigo fenders '93 Amigo - crawler in the works
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6024 MB (Peak: 0.6672 MB) Data Comp: Off Server Time: 2026-10-31 13:09:44 UTCValid HTML 5 and Valid CSS
