High flow cat or regular cat? Please put your 2 cents in...a.s.a.p. #660030 10/26/05 06:53 AM
W
Whatever Offline OP
My 1992 4x4 w/ 22re, 5spd, regular cab is all stock except rims and tires and is in need of a new catalytic converter. I would eventually like to do the complete exhaust with larger pipe and all that, but right now I'm just doin the cat. Should I go with a regular one or spend the extra money for a high flow? I'm looking for a direct-fit. This is a California vehicle. Any and all suggestions, recommendations, and/ or comments would be appreciated. I am kind of in a rush to do this though. Thanks in advance.
Re: High flow cat or regular cat? Please put your 2 cents in...a.s.a.p. [Re: Whatever] #660031 10/26/05 07:43 AM
L
lookmomnobrains Offline
alot of the newer cats flow better than the old ones ever did. high flow isnt needed unless you have a decent amount of mods. these motors arent beasts in most cases.
87 4runner 33" bfg mt's no lift. dubbed the marine by my frinds. dead as of august 14 2005. 84 ex cab p/u 33"a/t, 3" suspension+3"bodylift, thorley header and 2.25xhaust, downey midrange cam+rocker set, very milled head! NO RUST!
Re: High flow cat or regular cat? Please put your 2 cents in...a.s.a.p. [Re: lookmomnobrains] #660032 10/26/05 08:24 AM
Read this...
http://www.4crawler.com/4x4/CheapTricks/EngineMods/index.shtml
Besides what info you read there, i'll add my own opinion: Get a "high flow" cat. I don't know where you got your prices but you can pick one up all day long on eBay for $50-$60 shipped. Click Here
FYI, without adding all the tech stuff....a "high flow" cat and a regular new cat are pretty much the same.
Re: High flow cat or regular cat? Please put your 2 cents in...a.s.a.p. #660033 10/26/05 12:08 PM
all newer cats are "high flo" it just refers to the honeycomb style cats vs the older pellet styles of the late 70's don't be fooled by market hype,the oly time is flows more is if you get it in a larger pipe size like 2 1/4 vs 2 inch ends
Re: High flow cat or regular cat? Please put your 2 cents in...a.s.a.p. [Re: Whatever] #660034 10/26/05 02:37 PM
foxtrapper Offline
Normally, the "high flow" is marketing hype for charging more for a stock cat. But a true high flow cat would be nice.
Cats are mostly restrictive in their case design. It flares out and back quite quickly, blocking flow. A long taper flows much better. It doesn't look stock, and will probably give you problems in California with emissions inspectors when it comes to visual checks.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5999 MB (Peak: 0.6632 MB) Data Comp: Off Server Time: 2026-06-05 15:19:46 UTC
