carb swap
#662163
11/01/05 05:27 AM
im dropping a few more bucks into my truck. im running my 84 22r with a downey midrange cam and their rocker assembly now. i have a thorley header and 2.25 exhaust going in as well. what would be advisable for the carb? the stock one i have is crappy. i could rebuild it but would i be starving the motor for gas? i could also get the weber 32/26 if that would be better for my application. its a dd rig that will be regared soon (i hope) to 4.88 for my 33"a/t's im looking to get some more power as well as pick up a lil gas mpg.
87 4runner 33" bfg mt's no lift. dubbed the marine by my frinds. dead as of august 14 2005. 84 ex cab p/u 33"a/t, 3" suspension+3"bodylift, thorley header and 2.25xhaust, downey midrange cam+rocker set, very milled head! NO RUST!
Re: carb swap
[Re: lookmomnobrains]
#662164
11/01/05 03:30 PM
Technically the stock Aisin carb has a greater CFM than the Weber 32/36 so you are not starving your motor for fuel. I personally believe you can not beat the stock carb if it is setup right. I would rebuild the stocker or send it out to someone who knows how to rebuild carbs. If you have visual smog in your area the Weber will not pass.
John Smith 79 FJ40 87 StdCab w/22R TLCA# 9074
Re: carb swap
[Re: John Smith]
#662165
11/01/05 04:11 PM
I too was thinking about the Weber swap, but have also heard that the stock carb was way better. what's the best way to set up the stock carb for good performance? i'm sure lookmomnobrains would be interested as well!
-1986 TOYOTA 22R ZUK coil rear Torqued T-Bars Marlin HD clutch
AZTTORA #492 TLCA member
"I hear there's rumors on the Internets that we're going to have a draft." --George W. Bush
Re: carb swap
[Re: 4WD22R]
#662166
11/01/05 08:52 PM
I will beat your stock carb with a stick every time compared to my webers. I put a 32/36 on my dads truck to replace a good rebuilt stock carb and it's great. Better gas mileage and I was even able to hook up ALL of the emmisions (well less the charchol canisters <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> ).
My weber 38mm is awesomesauce also. The problem with them if you need to work on them. <img src="/forums/images/graemlins/shiner.gif" alt="" /> It takes some effort to get the going sometimes. But nice power up the yin-yang.
It is true the the CFM is lower on the 32/36 compared to the asian but they work much better. There are many differences in the way the carbs work. Notice on a stock carb the driver side choke plate stays closed most all of the time. It only opens with a high amount of vaccumm. This lowers the practical CFM of the carb to much lower than the weber that opens both choke plates at the same time, less restriction.
Josh
1986 Toyota 4x4 22wEBer Ported EB Offroad H/O Head "Josh Cam" Ported Intake & Weber38mm Carb LCE Header & 2.25in Exhaust RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
Re: carb swap
[Re: ArbitraryNotion]
#662167
11/01/05 09:52 PM
main reason im asking is because my truck dies out at 42-4300 rpms. the cat may be clogged so thats my reason for the exhaust(the whole thing is shot basically). but after reading these responses, i might just finish the exhaust and see how it decides to run then take my carb options from there.
Re: carb swap
#662168
11/01/05 10:33 PM
Josh, I am not sure how you managed to hook up the factory emissions devices to a Weber that lacks all the ports for the devices. <img src="/forums/images/graemlins/lol.gif" alt="" /> I guess AZ does not do visual under the hood inspections or require all factory controls to be in place, other locals do and will fail you in a second for a Weber or altered emissions.
I know you love your Webers, I have a few personal friends who run the 38 and they love them also. They most defintely did not like the hours/days it took to get them setup right though. Which you elude to in your post. <img src="/forums/images/graemlins/smile.gif" alt="" />
You stick with your Weber and I will stick with my pokey old Aisin. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: carb swap
[Re: John Smith]
#662169
11/01/05 11:06 PM
You'd be rather surprised how simple the EGR and A/S systems are hooked up when you have a FSM to look at. You need one manifold vac line and one venturi vac line and you are in business. Just takes some figuring...
I also got the adapter to use the stock aircleaner. I'm sure it will pass the visual test here in AZ. I'll have to get some pics of the setup.
Josh
Re: carb swap
[Re: John Smith]
#662170
11/02/05 12:54 AM
If you have visual smog in your area the Weber will not pass. just passed a month ago with my webber street lethal carb and all of the stuff below attached. o yea, and it does a great job. Of course it does not have as many ports as John Smith said, but who needs those anyway <img src="/forums/images/graemlins/lol.gif" alt="" /> i notice no change getting it setup right wasn't long, just normal installation and then fine tuning to where you want it. If your looking for a carb that you can customize and control, this one is great. I bought all of the different sized jettings with it so i could (and did) change the fuel flow i wanted to deliver, and i couldn't be happier. hope this helps <img src="/forums/images/graemlins/patriot.gif" alt="" /> just in case you wanna know, gettin 24mpg <img src="/forums/images/graemlins/kewl.gif" alt="" />
84x4 Toyota Ext. Cab Deluxe Not enough hours in the day to do what i want..... .....and sleep
Re: carb swap
[Re: Aaron84x4]
#662171
11/02/05 03:40 AM
i rebuilt the old weber 32/36 i had on my 20R, and put it on my hybrid a couple days ago.
now, i'm looking for creative ways of ridding the world of the menace i pulled off my engine. baseball bat, 30-06, crush with an excavator? and this is a 22R carb that i paid $300 to have rebuilt in january. should've been smart and gone with the weber from the get-go.
one thing i noticed, is how well it runs, even with the choke deleted(i removed all the linkage, shaft, butterflies etc). problem was that it had baseline jets, and i had to step up 2 sizes in idle jets to get it right. always ran way lean on my old engine, that's why i guess.
the 22R carb was nice when i first put it on, but it ran way too lean. worst part is that it's not easily adjustable, worse case with the weber is that i might have to spend 10 minutes pulling the top off and replacing the main or air jets <img src="/forums/images/graemlins/kewl.gif" alt="" />
'79 sport 4x4 longbed <img src="/forums/images/graemlins/smile.gif" alt="" /> 20/22R hybrid with EB's OS valves, 268c cam, offy intake, weber 32/36, thorley header, 5 speed swap, 34" LTBs, downey 3" springs, marlin hysteer, 4.88s and locked
'91 4x4 shortbed 22R-E, W56, the dd!
Re: carb swap
#662172
11/02/05 04:20 AM
My 38 was easy to set up and is easy to maintain. Changing jets is a five minute deal. Now I do wonder if I could do better on milage with the 32/36. I drive 70-75 and get 17, 18 on longer trips and 16 offroad very consistently.
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
