Re: Temporary Ball Joint Fix??? [Re: mjc] #662788 11/08/05 05:32 AM
9
94redrodeo Offline
Based on what mlclark said a Isuzu ball joint is not designed to completley fail. An 87 fiero "will" fail not just the ball joint the whole vehicle <img src="/forums/images/graemlins/lol.gif" alt="" />
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
Re: Temporary Ball Joint Fix??? [Re: 94redrodeo] #662789 11/08/05 06:46 AM
Jim_Paget Offline
I have a good friend who had an early Fiero. The best thing that can be said about them is that you will never find a high mileage Fiero (It is impossible to keep one running long enough to accumulate much mileage).
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Temporary Ball Joint Fix??? [Re: Jim_Paget] #662790 11/08/05 05:05 PM
langforg Offline OP
I'm going to pick up the BJ later on today. Also noticed something else... The steering wheel is off-center by about an 1/8 of a turn. Could this be related to my BJ troubles or should I be looking for another problem.
Brad
95 Trooper,3in Lift,15x10 AR-23 Wheels, 33x12.50 BFG AT's, SuperWinch Hubs,Rock Sliders,Tie-Rod Shields,Cross-Drilled Brake Rotors,ARB Bull Bar...,looking for cheap winch.
Re: Temporary Ball Joint Fix??? [Re: langforg] #662791 11/08/05 05:11 PM
Starchild Offline
That depends on wether it was that way before Uhwarrie or not. If it's been that way, it probably was just not centered when it was last alligned. If this developed after the trip, I would look for "tweaked" steering linkage, most likely tie-rods.
Good luck
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: Temporary Ball Joint Fix??? [Re: Jim_Paget] #662792 11/09/05 12:49 AM
mlclark Offline
Isuzu Moderator
It is a balance. They don't run long enough to accumulate mileage, but they do run long enough to catch on fire. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6117 MB (Peak: 0.6768 MB) Data Comp: Off Server Time: 2026-06-23 14:16:16 UTC
