Page 2 of 3 1 2 3
Re: I have a secret ... (pics of my SAS) [Re: Landmonster] #663379 11/05/05 11:39 PM
jgalt Offline OP
Handling is definitely a concern as this is my daily driver and I am very concerned about handling under "evasive maneuvers at highway speeds.
That said, we did construct this system with about 12* positive camber on each side so handling from this standpoint is no problem.
Where I'm having a bit of a problem in handling is the width of the tire (13.5") compared to the stock steering box and body lift, which left my steering shaft angled at the compression point.
I currently plan on modifying the steering box (and porting it for later hydraulic assist) for fewer turns lock to lock and changing the angle of the steering shaft mounting plates to address these issues.
Jim - ZU'tah Wheeler
'96 Rodeo LS 4x with 3.2L SOHC V6 (6VD1-V) & MUA5
Beyond that <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: I have a secret ... [Re: jgalt] #663380 11/06/05 05:45 AM
Sammy Offline
Hell of a job you guys did. Wish I could get mine that nice and clean looking. Get some more photos up.
Sammy
95.5 Rodeo, automatic, 3.2 SOHC, D44 front and rear, 4.88's, 33" muds
Re: I have a secret ... [Re: Sammy] #663381 11/07/05 04:19 AM
onebadtrooper Offline
Wow.......I'm going to do that exact same thing, but no airshocks, I'm going with coils....I'm going to be asking you alot of questions, when my sas comes around <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: I have a secret ... [Re: onebadtrooper] #663382 11/07/05 05:28 AM
CPOM Offline
looks nice.. <img src="/forums/images/graemlins/cheers.gif" alt="" />
CHRIS
98 Amigo, 92 Pup
Re: I have a secret ... [Re: onebadtrooper] #663383 11/07/05 05:30 AM
randii Offline
How big are the air shocks? I like air shox for affordability, but I didn't know how they'd handle the weight of my pig of a rig. How much are you having to pressurize the shox, Jim?
Randii
Re: I have a secret ... [Re: randii] #663384 11/07/05 05:45 PM
Jonesy Offline
Well I will say, the pics don't do it justice. This is a beautiful truck. Everything is very beefy(From what I can see anyway) The system looks pretty solid, however, I am sure Jim will find a way to break it(oops, he already has <img src="/forums/images/graemlins/shiner.gif" alt="" />)
I guess he lost all the rear diff fluid and fried the R&P...something to do with the design of the rear diff cover and breather tube.
Anyway, it is a good looking truck....all components seem well thought out and beefy....I want to see all the pics since I couldn't really roll around in the street looking at the underside.
Steve
'97 Rodeo
3.2L V6
DOR 3" lift, 3"BL, DOR Boulder Bars, Tera-Low's, 33x10.5,Surco Safari Rack, Cobra CB, Rancho 9000's....andnNow with Half-Doors for the summer
Re: I have a secret ... (pics of my SAS) [Re: Sammy] #663385 11/07/05 06:28 PM
jgalt Offline OP
Sammy - Hell of a job you guys did. Wish I could get mine that nice and clean looking. Get some more photos up.
Thank you and pics are posted (well almost). I've sent all the pics of my conversion progress to Koby who is busy posting them on our ZU'tah Wheeler Gallery
onebadtrooper - Wow.......I'm going to do that exact same thing, but no airshocks, I'm going with coils....I'm going to be asking you alot of questions, when my sas comes around
I looked at the same thing (coils); the problem I had was that we'd have to cut through the rear fender wells and brace accross through the cabin <img src="/forums/images/graemlins/scared.gif" alt="" />. With the air shocks, I could keep it compact and mounted under (as opposed to through) the body, which is important because this is where I sleep when Miss Ramie is ticked off at me <img src="/forums/images/graemlins/shiner.gif" alt="" />.
CPOM - looks nice..
Thanks Chris - check out the new pics <img src="/forums/images/graemlins/kewl.gif" alt="" />
randii - How big are the air shocks? I like air shox for affordability, but I didn't know how they'd handle the weight of my pig of a rig. How much are you having to pressurize the shox, Jim?
The socks are 12" SwayAways and yes, they are definitely more affordable at about $250/shock vs ~$700 for coils and shocks or coils over shocks. Getting the right balance has been a bit of a trick, but we're closing in on it. We have realized that the valves and shim packs that came with the shocks are insufficient for the weight and have ordered new valves and shim stacks to firm up the ride and reduce lean on turning. We did also put in a rear sway bar, though I don't think I took a pic of it. As soon as we get the new valves and shims in I'll post up with the pressure #s.
Jonesy - The system looks pretty solid, however, I am sure Jim will find a way to break it(oops, he already has )
<img src="/forums/images/graemlins/ignore.gif" alt="" /> Thanks Jones! <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Yeah, and I can't for the life of me figure out how this happend <img src="/forums/images/graemlins/confused.gif" alt="" />. In any event, we've capped the breather on the diff cover and put one directly on the axle tube. Hopefully this, together with relocating the breather tube will address the problem.
Re: I have a secret ... (pics of my SAS) [Re: jgalt] #663386 03/27/06 11:35 PM
BroncosFan Offline
How about an update? I am real curious to know if you've gotten the shocks tuned for good road/highway handling. Also, can I see some pics of the finished product?
Thanks, Lester
<img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
'92 Pickup - 2" BL, 1.5" SL, 4.3 TB swap, 2.25" exhaust, Amigo fenders
'93 Amigo - crawler in the works
Re: I have a secret ... (pics of my SAS) [Re: BroncosFan] #663387 03/28/06 04:51 AM
Billdo Offline
$250 a shock, where did you find those at?
2000 Chevy Tahoe nothing special. 1990 Isuzu Amigo, 3" lift, 31x10.5x15 BFG All Terrain (Street), 33x12.5x15 (offroad), Pacesetter header, some ATM rash. More mods to come......
Re: I have a secret ... (pics of my SAS) [Re: Billdo] #663388 03/29/06 02:13 PM
Man that is so sweet. i wish i could do that to my 94 <img src="/forums/images/graemlins/frown.gif" alt="" /> click here to see my rodeo. i couldnt figure out how to put pic in post ???
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6443 MB (Peak: 0.7558 MB) Data Comp: Off Server Time: 2026-06-07 05:01:15 UTC
